-   OpenFOAM (https://www.cfd-online.com/Forums/openfoam/)
-   -   problem with paraView (https://www.cfd-online.com/Forums/openfoam/87473-problem-paraview.html)
tH3f0rC3 April 21, 2011 01:52
1 Attachment(s)
sometimes after I solved a case I can't watch the result because the solved case looks like in the picture below. (Normally there are colored surfaces)
Is there a mistake in the step of solving or in the step of paraviewing?
Best Regards,
tH3f0rC3
kurne April 21, 2011 02:07
Hi
If the geometry is complex then the outline is came in the browser, this is due to complex geometry only what i experience.
If there is any reason then i dont know it.
tH3f0rC3 April 21, 2011 05:20
Ok, the complex geometry can be a reason.
But I can view the same model solved with chtMultiRegionSimpleFoam.
Tobi April 21, 2011 05:39
Originally Posted by tH3f0rC3 (Post 304530)
Hi Dirk,
you have to put the "outline" to - > "surface" then you got your display.
If the mesh and geometry is large (size), paraview uses the Outlines as a standard preferences.
Tobi
tH3f0rC3 April 21, 2011 05:52
That's it!
Thank you! :-)
tH3f0rC3
