May 8, 2011, 13:23 |
simple mesh with arcs
Mike
Rep Power: 14 |
Hi, I am trying to create a simple mesh using blockMesh utility, like this one:
https://docs.google.com/leaf?id=0Bw0...thkey=CIWG25EF The problem is, that when I type "checkMesh", it gives out 3 errors, as shown here: https://docs.google.com/leaf?id=0Bw0...thkey=CNHAj8MB But I can't figure out what the problem might be. Does anybody have an idea? Thank you! ps: this is the blockMeshDict file that I used: https://docs.google.com/leaf?id=0Bw0...thkey=CIG149MM |
May 9, 2011, 03:47 |
Dejan Morar
Rep Power: 16 |
Hello Mike,
I've just divided yours geometry into two blocks and everything works fine. convertToMeters 0.1; vertices ( ( 1 0 0 ) ( 2 0 0 ) ( 0 2 0 ) ( 0 1 0 ) ( 0 -1 0 ) ( 0 -2 0 ) ( 1 0 1 ) ( 2 0 1 ) ( 0 2 1 ) ( 0 1 1 ) ( 0 -1 1 ) ( 0 -2 1 ) ); edges ( arc 1 2 (1.414213562 1.414213562 0) arc 0 3 (0.707106781 0.707106781 0) arc 0 4 (0.707106781 -0.707106781 0) arc 1 5 (1.414213562 -1.414213562 0) arc 7 8 (1.414213562 1.414213562 1) arc 6 9 (0.707106781 0.707106781 1) arc 6 10 (0.707106781 -0.707106781 1) arc 7 11 (1.414213562 -1.414213562 1) ); blocks ( hex (0 1 2 3 6 7 8 9) (10 10 10) simpleGrading (1 1 1) hex (4 5 1 0 10 11 7 6) (10 10 10) simpleGrading (1 1 1) ); patches ( patch inlet ( (3 9 8 2) ) patch outlet ( (5 11 10 4) ) wall walls ( (1 2 8 7) (5 1 7 11) (3 0 6 9) (0 4 10 6) ) empty front ( (0 1 2 3) (4 5 1 0) (6 7 8 9) (10 11 7 6) ) ); Sorry because I changed numbering of your original geometry. Regards, Dejan |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
Simple Icem mesh | Kordou | CFX | 2 | September 22, 2008 08:53 |
Very simple moving mesh | Pete | FLUENT | 4 | February 10, 2006 00:12 |
