May 4, 2011, 21:54 |
Getting GGI-ready mesh from conversion
Robert
Rep Power: 15 |
I am trying to use Pointwise to create structured meshes for a GGI case (which I run unstructured grids with successfully). The openfoam export does not seem to be ready for ggi (includes 'boundary','faces','neighbor','owner','points'). So I try to export it to fluent and convert it.
My question is, has anybody converted a fluent mesh for ggi? |
May 5, 2011, 10:42 |
BastiL
Rep Power: 20 |
May 5, 2011, 10:59 |
sirLentschi
Rep Power: 15 |
Yes I have converted some fluent-meshes to Foam with fluent3DMeshToFoam.
But take a look on your converted patches - maybe you have to change them (for example from "wall" / "patch" to "ggi") in OpenFoam! Regards |
May 5, 2011, 12:05 |
Robert
Rep Power: 15 |
Thanks guys for the responses.
So whenever I convert the mesh it doesnt seem to be ggi-ready and im not sure what to do. I noticed that 'cellZones' is created but it is empty. Is this an essential file for ggi? |
May 6, 2011, 04:58 |
sirLentschi
Rep Power: 15 |
you can get "CellZones" with the command "splitMeshRegions -makeCellZones".
In your boundary-file you have to define the desired ggi-patches - take a look on the validation test cases to get an overview of setting up a case! http://openfoamwiki.net/index.php/Si...ion_test_cases In the "centrifugal pump" there is described how to create ggi patches correctly. |
May 8, 2011, 20:14 |
Robert
Rep Power: 15 |
Thanks guys for the replies. I have been able to make progress with you all's help, but still I face a problem. The following is the procedure I used to generate the mesh case: (ggi, there exists a rotor and stator)
1. Pointwise 3D mesh OpenFoam export for 2 grids (rotor and stator), 5 files each (boundary, points, faces, neighbor, owner) 2. mergeMeshes 3. splitMeshRegions -makeCellZones 4. setSet -batch setBatch (file 'setBatch' contains: (line 1) 'faceSet insideZone new patchToFace insideSlider' (line 2) 'faceSet outsideZone new patchToFace outsideSlider' (line 3) 'quit') 5. setsToZones -noFlipMap Then i run it using 'decomposePar' and 'foamJob -s -p turbDyMFoam'. It runs for a while, but then things start going crazy on the readout, because i have not set it up for ggi to work properly, please see the attached images of the ggi interface. Anybody know what I am doing wrong? I will be trying to debug this and try splitMeshRegions on a Pointwise export with both rotor and stator in one mesh (differently defined cell 'sets') to see if that works. |
May 9, 2011, 03:39 |
sirLentschi
Rep Power: 15 |
do you set up the "dynamicMeshDict" file?
please post your boundary- and the dynamicMeshDict-file and the log-files of checkMesh and your run , so that we can get an overview of your problem! What happens,if you run the solver with only ONE CPU?? |
May 9, 2011, 09:06 |
Robert
Rep Power: 15 |
Attached are the 3 files you requested. I will try serial run and let you know how that goes.
The case is an o-grid external flow (so it has a circular outer boundary). |
May 9, 2011, 09:25 |
#9 |
sirLentschi
Rep Power: 15 |
Did you adapt your field-files correctly (in the field-files there are "boundary-fields" too, and they must have the same entries as your boundary-file!!)?
In the cellZones-file, the ROTATING ZONE MUST have the name "movingCells" - ckeck this out! (If you use a transient solver,you do not need to create a cellZones file, mixerGGI... will do this for you!Delete the cellZones-file,start the solver and check the things I described above). ...and please post the log of your calculation!! |
mesh conversion for dispersed liquid drop flowing upward in a continous phase | hossein.mashhadi | OpenFOAM Running, Solving & CFD | 0 | February 3, 2011 16:42 |
mesh conversion for dispersed liquid drop flowing upward in a continous phase | hossein.mashhadi | OpenFOAM | 0 | February 2, 2011 10:43 |
[Commercial meshers] ansys icem tetra mesh to fluent_v6 conversion problems | milleniumrider | OpenFOAM Meshing & Mesh Conversion | 3 | May 13, 2010 14:54 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Turbogrid-icem mesh ggi | Kumar | CFX | 1 | May 18, 2007 04:19 |
