Unsteady simple-based sovler and dual time stepping
Old   May 17, 2011, 09:26
Default Unsteady simple-based sovler and dual time stepping
L1011 is on a distinguished road
Hi Foamer!
I've been interested in implementing in openFoam the simple algorithm for the simulation of unsteady flows with a dual time stepping method. Before I start coding any stupid thing, I was wondering if:
  1. adding a time derivative in the currant simpleFoam solver is enough to make it become unsteady
  2. you could refer to me articles that discuss the dts implementation in incompressible solvers
It'll be interesting to see how an unsteady simple-based solver behave with respect to pisoFoam.
Great thanks!
L1011
L1011 is offline   Reply With Quote
Old   May 17, 2011, 09:40
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
...and pimpleFoam is not good enough because?
niklas is offline   Reply With Quote
Old   May 17, 2011, 09:48
Nima Samkhaniani
nimasam is on a distinguished road
i guess so, add fvm::ddt(U) to UEqn then
compare the result of simpleFoam for cavity with pisoFoam
nimasam is offline   Reply With Quote
Old   May 18, 2011, 11:28
Default Hi!
Thanks for your responses!
@Niklas: you're right pimpleFoam already provides the implementations I intended to do. But what about the dual time stepping? In fact what I'm trying to do is, for each physical iteration:
  1. move/deform a mesh
  2. execute sub-iterations until convergence is reached
  3. back to 1
and I'm wondering if the correction loops (nNonOrthogonalCorrectors, nOuterCorrectors, nCorrectors) can be considered as sub-iterations in the same meaning of the dual time step method?
L1011
Old   May 20, 2011, 11:17
Any guesses?
I used pimpleFoam to simulate the flow around a NACA0012 airfoil and the following settings:
| \      /  F ield         | OpenFOAM: The Open Source CFD Toolbox           |
|  \    /   O peration     | Version:  1.7.1                                 |
|   \  /    A nd           | Web:      www.OpenFOAM.com                      |
|    \/     M anipulation  |                                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         backward;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
    grad(U)         Gauss linear;
divSchemes
    default         none;
    div(phi,U)         Gauss limitedLinearV 1;
    div(phi,k)         Gauss upwind;
    div(phi,omega)         Gauss upwind;
    div((nuEff*dev(grad(U).T())))         Gauss linear;
laplacianSchemes
    default         none;
    laplacian(nuEff,U)          Gauss linear corrected;
    laplacian((1|A(U)),p)          Gauss linear corrected;
    laplacian(DkEff,k)          Gauss linear corrected;
    laplacian(DomegaEff,omega)          Gauss linear corrected;
interpolationSchemes
    default         linear;
    interpolate(U)           linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p       ;
/*--------------------------------*- C++ -*----------------------------------*\n| =========                 |                                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver          GAMG;
        tolerance       1e-7;
        relTol          0;
     mergeLevels  1;
     smoother  GaussSeidel;
     agglomerator faceAreaPair ;
     nCellsInCoarsestLevel  100;
     nPreSweeps 0;
     nPostSweeps 2;
     cacheAgglomeration true;
    pFinal
        solver          GAMG;
        tolerance       1e-7;
        relTol          0;
     mergeLevels  1;
     nPreSweeps 0;
     nPostSweeps 2;
    U
        solver          smoothSolver;
        tolerance       1e-7;
        relTol          0;
    nSweeps  2;
    UFinal
        tolerance       1e-7;
        relTol          0;
    nSweeps  2;
    k
    smoother GaussSeidel ;
    nSweeps 1 ;
        tolerance        1e-7;
        relTol           0;
    omega
    nSweeps 1 ;
        tolerance        1e-7;
        relTol           0;
    PIMPLE
        nNonOrthogonalCorrectors 4;
       pRefValue 1;
       pRefCell 0;
        nOuterCorrectors 10;
        nCorrectors     2;
      relaxationFactors
       default                  1;
        p                  0.5;
        U                  0.5;
        k                  0.5;
        omega                  0.5;
However,I made two strange observations:
1) Even-tough the aerodynamic coefficients get in absolute close to zero, they change significantly from one iteration to the other (see attached file).
2) The velocity field converges from the first outer iteration while the pressure needs couple iteration to get physical.
Do anyone has already experienced something similar?
Thanks in advance!
L1011
