May 21, 2011, 05:19 |
b eqn in XiFOAM
Farshad
I have used ignition in XiFoam, but the b variable never changes from 1 inside my domain which is a premixed burner. I have this problem in both RANS and LES simulation. Kind Regards, Farshad |
May 22, 2011, 12:10 |
this means that no combustion has occured. Could you provide us with some more details. What are ur boundary conditions? Log file.. Peter |
May 24, 2011, 02:20 |
case
Farshad
Dear Peter,
I have attached my boundary conditions. The case is a premixed burner with a simple flameholder. The outlet is atmosphere. please tell me why ignition does not occur. Kind Regards, Farshad |
May 24, 2011, 07:38 |
Does the solver find the ignition cells? Is it explicitly written on the screen?
Maybe change the postion of the ignited cells. |
May 24, 2011, 11:16 |
Farshad
Thanks. Is it true that ignition cell location should be in meters? I changed the position very much but it nothing happened. Am i correct about other options in ignition sites? Did you look at my case? Is it ok about igintion sites? Thanks Farshad |
May 24, 2011, 11:41 |
Hi
Could you please post the output of the beginning of ur simulation? Or logfile? I ve no experiences with burners, because I am using the premixed combustion model for internal combustion engines. Thus I don t know if ur bc are right. But I will face that problem also very soon. Have you tried to use the values given by the tutorials in the XiFoam folder? Peter |
May 28, 2011, 14:36 |
Farshad
Dear Peter,
I do not receive any error in my simulation and i used the same boundary condition for LES of XiFOAM for 2D case given in the tutorial. My problem is that only my b variable doesnt change from 1. Thanks Farshad |
Specific heat, density evaluation in mixture eqn | CFDtoy | Main CFD Forum | 1 | January 29, 2008 03:08 |
Multigrid or Krylov subspace for poisson eqn | zonexo | Main CFD Forum | 1 | May 5, 2006 04:26 |
Define new Reynolds stress term in momentum eqn. | satoshi | FLUENT | 0 | November 6, 2005 23:12 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 14, 2000 00:03 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 11, 2000 04:43 |
