Compiler problem?
Hello people,
I think I have a compiler problem when I'm running the tutorials cavity in pisoFoam (ras) and cavityClipped in icoFoam. For example when I use "$ mapFields ../cavity" command in the latter, I get- --> FOAM FATAL ERROR: Cannot find file "points" in directory "polyMesh" in times 0.5 down to constant From function Time::findInstance(const fileName&, const word&, const IOobject::readOption) in file db/Time/findInstance.C at line 175. FOAM exiting My versions of OpenFOAM and Paraview are 1.7.1 & 3.8.1 respectively. What should I do? |
did you use the blockMesh command to create geometry?
Thanks, yeah, I had. Apparently it hadn't worked due to some reason. I quit the terminal and repeated the "$blockMesh" command. Then, I encountered no glitches. So basically, if OpenFOAM has been installed properly, there shouldn't be any C++ compiler problems while running it, right?
P.S.- This post is quite silly now, I should probably remove it. :p |
Above error said that points has not been found so it mightbe not created yet! ;) so probable mistake could be that you forget to use blockMesh command :)
besides if you in doubt that the openFOAM has been installed properly or not go to bin directory and use ./foamInstallationTest and check configuration |
