Computing Streamwise Turbulent HeatFlux
Old   May 28, 2011, 10:06
Default Computing Streamwise Turbulent HeatFlux
n/a
deji is on a distinguished road
Hey there Foamers, I would like to confirm my understanding of calculating the streamwise turbulent heatflux, uT:
If I know Urms and Trms, can I take the product
uT= UrmsTrms ??
Thanks.
deji is offline   Reply With Quote
Old   May 30, 2011, 05:49
Thomas Baumann is on a distinguished road
Hallo,
you can't do this:
you have to define the vectorfield
u*T, and get the mean-values out of this product and so get from this your rms values.
Thomas Baumann is offline   Reply With Quote
Old   May 30, 2011, 10:22
n/a
Thanks for the reply. I have checked, but it seems OpenFOAM fieldAverage does not have the capability of averaging u'T',v'T'. Is that so? Thanks much in advance.
Deji
Old   June 1, 2011, 05:29
I would rewrite the solver and get an output similar to:
volVectorField UT
IOobject
"UT",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
U*T
and than in the controlDict:
functions
fieldAverage
type fieldAverage;
functionObjectLibs ("libfieldFunctionObjects.so");
enabled true;
outputControl outputTime;
fields
UT
mean on;
prime2Mean on;
base time;
Regards Thomas
Old   June 1, 2011, 11:32
n/a
Thank you very much Thomas.
Best regards,
Deji
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 18 September 15, 2022 07:08
Turbulent Dispersion for Coal Combustion gravis CFX 2 March 23, 2010 23:56
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
