Non-uniform Unsteady Periodic Inlet Boundary Conditions in OpenFOAM |
November 19, 2018, 20:44 |
Harshal Akolekar
Rep Power: 9 |
I am trying to simulate a turbine blade with unsteady incoming wakes in OpenFOAM. For the same, I want to use non-uniform inlet profiles of totalPressure, totalTemperature, pressureDirectedInletVelocity, fixedValue TKE and fixedValue omega, which are from high-fidelity simulations and are representative of a wake downstream of a turbine blade. Using these profiles saves computation time. These profiles should however be able to move in the pitchwise direction with a user defined velocity and they should also be periodic in the pitchwise direction. Can anyone please provide suggestions on how to get started with this problem. Attached is a simple sketch Thank you. Regards, Harshal p { margin-bottom: 0.25cm; line-height: 120%; } |
November 19, 2018, 20:45 |
Harshal Akolekar
Rep Power: 9 |
Display Modes | |
wallHeatFlux utility for an incompressible case | Mr.Jingles | OpenFOAM Post-Processing | 67 | April 6, 2023 04:25 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 19:02 |
Divergent temperature in chtMultiRegion(Simple)Foam | akrasemann | OpenFOAM Running, Solving & CFD | 13 | March 24, 2014 03:54 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
Need help with boundary conditions: open to atmosphere | Wolle | OpenFOAM | 2 | April 11, 2011 08:32 |
