how to increase maximum number iterations to > 1000?
Old   June 11, 2011, 21:50
Default how to increase maximum number iterations to > 1000?
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
I am solving an interFoam case. When solving p_rgh, maximum iterations is 1000 (when using PCG). Is there a way to increase to a higher number?
Thanks!
Pei
phsieh2005 is offline   Reply With Quote
Old   June 12, 2011, 08:18
David Boger
boger is on a distinguished road
lduMatrix has a maxIter parameter, at least in the version of OpenFOAM I'm looking at
David A. Boger
boger is offline   Reply With Quote
Old   June 12, 2011, 09:28
Pei-Ying Hsieh
Hi, David,
Thanks for the reply!
But,where can I find lduMatrix?
Pei
Old   June 12, 2011, 09:40
Pei-Ying Hsieh
Hi, David,
OK, I found lduMatric.H that references maxIter. But, I am still looking for where maxIter is given.
See you at PSU tomorrow.
Pei
Old   June 12, 2011, 09:41
David Boger
You can find lduMatrix as a class in the C++ code, either through the files or through Doxygen (e.g. go to http://www.openfoam.com/docs/cpp/ and search for maxIter).
If you're not interested in the source code, the point is this: you can add maxIter as an entry in your PCG dictionary in fvSolution and set its value to whatever you want. (1000 is the default.)
David A. Boger
Old   June 12, 2011, 09:50
Pei-Ying Hsieh
Hi, David,
Thanks a lot!
I found out that the default was set in lduMatrixSolver.C.
Also nice to know that I can specify this in PCG dictionary without changing the source code.
Pei
Old   September 25, 2011, 17:02
Dimyriiy Bogdanov
dimyriy is on a distinguished road
Thanks. Your topic unbelievable helps me!!
dimyriy is offline   Reply With Quote
icoLagrangianFoam OF1.6 myNewParticleSolver heavy_user OpenFOAM 23 June 2, 2020 02:18
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
