PathScale EKOPath 4 Compiler Suite is free and open source |
June 14, 2011, 01:50 |
Alberto Passalacqua
Rep Power: 36 |
PathScale EKOPath 4 Compiler Suite has been released as an open source project for Linux, FreeBSD and Solaris. Here the official announcement:
http://www.pathscale.com/ekopath4-op...e-announcement The download link is a bit hidden here: http://www.pathscale.com/ekopath-compiler-suite and it is http://c591116.r16.cf2.rackcdn.com/e...-installer.run Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. Last edited by alberto; June 14, 2011 at 02:02. Reason: Added download links |
June 14, 2011, 05:06 |
Olivier
Rep Power: 17 |
hello,
Does someone have already setup environement (i.e bashrc and settings.sh) in order to use this pathscale compiler with OpenFOAM ? NB: actual files seems GCC centric. PS: trying to keep "Gcc" but changing export WM_CC='/opt/ekopath-4.0.10/bin/pathcc' export WM_CXX='/opt/ekopath-4.0.10/bin/pathCC' does not work. thirdParty (from scotch) gives error thus either the rest. edit: in fact, error are from mpicc Regards, olivier Last edited by olivierG; June 14, 2011 at 07:00. |
June 14, 2011, 10:04 |
Alberto Passalacqua
Rep Power: 36 |
I doubt: the compiler was open-sourced yesterday ;-)
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
June 14, 2011, 11:42 |
#4 | ||
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
@Olivier: Quote:
I haven't tested this myself, but here's a short list of the files you will need to take a look at:
Keep in mind that probably you will have to change the rules in the folder "rules/linuxPathCC", in order to comply with pathcc's options And I quote: Quote:
@Alberto: Shouldn't the OpenFOAM code need some massive restructuring for taking full advantage of PathCC? Or at the very least, adding OpenMP to the Pstream library? Best regards, Bruno
June 14, 2011, 11:56 |
#5 | |
Alberto Passalacqua
Rep Power: 36 |
If you mean re-writing parts of the code so that parallelisation is done with OpenMP, then yes, you need a lot of restructuring. If you choose to rely on the automatic features of the compiler for that (it seems PathScale strong point is exactly this) , then you only need "minor" changes: rewriting the compilation rules, tuning the options, and eventually patch those parts of the code that do not build. Best,
June 14, 2011, 19:00 |
Laurence R. McGlashan
Rep Power: 23 |
Just tried this on our cluster on an in-house C/C++ code base (lots of monte carlo in it) with the same optimisation flags (-O2/-O3) as Gcc and it's twice as slow. Bit disappointed initially but will have a look again sometime later this week.
Laurence R. McGlashan :: Website |
June 14, 2011, 22:55 |
Alberto Passalacqua
Rep Power: 36 |
Looks a bit strange. However, if you do not find the reason, tell them (Freenode - #pathscale channel). Their motto is "if it's not faster than gcc, then it's a bug"
June 15, 2011, 15:34 |
#8 | |
Bruno Santos
Rep Power: 128 |
Greetings to all!
But I'll remind you that gcc 3.{3,4}.x was waaaay slower that gcc 4.{3,4,5}.x! And according to their docs I posted before, their "arguments" reference for gcc was still "gcc 3.3.1", sooo... Best regards, Bruno
June 15, 2011, 17:54 |
#9 |
Rep Power: 23 |
Good old benchmarks!
Yes, I have timings for gcc3.4 for my apps and the simulations are generally around 10% slower than with gcc4.6. pathCC is, like, TWICE as slow with the same flags (even had a look at a few of the extra ones, but no luck). Anyway, better stop procrastinating. If anyone gets decent results using this then it would be nice to know.
June 15, 2011, 18:34 |
#10 |
Alberto Passalacqua
Rep Power: 36 |
This sounds a interesting, given that on benchmarks the performance improvement of PathScale is quite large compared to gcc 4.5.2 (there is a test with Poisson solvers):
http://www.phoronix.com/scan.php?pag...th4_open&num=3 http://www.phoronix.com/scan.php?pag...th4_open&num=4 Best,
June 16, 2011, 05:33 |
#11 |
Rep Power: 23 |
Well I just tried Himeno bench 98 source code and got this (am I being fair?):
gcc (GCC) 4.6.0 20110530 (Red Hat 4.6.0-9) gcc -c -O3 -DLARGE himenoBMT.c gcc -O3 himenoBMT.o -o bmt ./bmt mimax = 513 mjmax = 257 mkmax = 257 imax = 512 jmax = 256 kmax =256 cpu : 46.553092 sec. Loop executed for 100 times Gosa : 4.882812e-04 MFLOPS measured : 2403.078704 Score based on MMX Pentium 200MHz : 74.467887 Code:
PathScale (tm) Compiler Suite: Version 4.0.10 GNU gcc version (PathScale 4.0.10 driver) pathcc-4.0.10 -c -O3 -DLARGE himenoBMT.c pathcc-4.0.10 -O3 himenoBMT.o -o bmt ./bmt mimax = 513 mjmax = 257 mkmax = 257 imax = 512 jmax = 256 kmax =256 cpu : 66.520140 sec. Loop executed for 100 times Gosa : 4.882812e-04 MFLOPS measured : 1681.757495 Score based on MMX Pentium 200MHz : 52.115200
June 20, 2011, 14:22 |
#12 |
Rep Power: 23 |
Small update: The above case will run just as fast with the pathcc compiler if you use the -LNOrefetch=0 flag.
So I wouldn't trust any benchmarks, especially if they're not at least compared with the GCC4.6 compiler with -O3 turned on.
June 20, 2011, 15:17 |
#13 | |
Alberto Passalacqua
Rep Power: 36 |
Could you report the case to PathScale guys? I showed them this thread, and they asked to open a bug report so that they can examine the case, but I do not know the details of what you did. About benchmarks, they are really case- and hardware-specific. Also, there is another factor: what compiler was used to build the compiler and libraries? Best,
June 26, 2011, 18:48 |
#14 |
Niels Nielsen
Rep Power: 27 |
I also tested this against the std 4.4.x version in SL6.0 and pathCC is WAY slower than gcc in the std icoFoam readme tutorial.
Linnemann PS. I do not do personal support, so please post in the forums. |
June 26, 2011, 20:33 |
#15 |
Alberto Passalacqua
Rep Power: 36 |
Yes, I did not have good results either in comparison to a standard build with gcc 4.5.1 on openSUSE 11.4. I'll try to file a bug report, since that's what they suggested to do.
@Niels: Our of curiosity, what options did you use? Best,
June 26, 2011, 20:54 |
#16 |
Niels Nielsen
Rep Power: 27 |
Basically just the gcc ones without one option, cant remember which one but pathCC complained about it and just removed it from the c++ rules of wmake.
Open Source DEM with LIGGGHTS: Release / classes | chrisk | Main CFD Forum | 1 | October 31, 2022 15:41 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
The CERFACS' PALM coupler is now open source (LGPL 3.0) | Florent | Main CFD Forum | 0 | January 30, 2011 14:59 |
Dual Boot Windows and Linux and Go Open Source | andyj | Main CFD Forum | 2 | October 21, 2010 16:49 |
Elmer a Free, Open Source Multiphysics Programme | Ahmed | Main CFD Forum | 0 | September 19, 2009 19:30 |
