buoyancy lift & Buoyancy drag on a moving paddle
Old   July 16, 2013, 01:50
Default buoyancy lift & Buoyancy drag on a moving paddle
hhh
kunar
hhh is on a distinguished road
Good Day Friends,
Kindly see this you tube link [ http://www.youtube.com/watch?v=2pP2hFbcqw4 ]
I already design this vehicle in catia. I want to see the buoyancy lift & Buoyancy drag. I create mesh in ICEM CFD, But I want to flap all the paddle up & down. In fluent UDF is there, but I want to do in Open Foam is Its Possible?
For example if left side paddle flaps very less speed when compared to right side paddle it turns left, similarly for all orientation ie pitch,roll, Hovering ( its all depends the variation of speed in that paddle)
Kindly give your suggestion, how I can solve and set case file for this problem in open foam.
Thanks for your valuable time
kunar
hhh is offline   Reply With Quote
[OpenFOAM] Display lift and Drag in paraview SamerAli ParaView 1 May 16, 2013 12:51
Measuring Lift and Drag on Moving Body sheth FLUENT 0 March 20, 2012 10:32
Lift and Drag Monitor Point Values Converging to Zero Josh CFX 24 May 9, 2011 10:38
CFX - Flow Over a Moving Body (Lift & Drag) rossbardon CFX 2 January 6, 2010 19:14
Correct lift but wrong pressure drag - possible? zx Main CFD Forum 4 July 27, 2007 23:38
