June 23, 2011, 09:24 |
simple 3D pipe flow diverges with icoFoam
Roland
Hello!
I am trying to get grips with OpenFoam. I set up a really EASY case. It is some kind of straight tube. The simulation should be easy, but after 6 iterations, icoFoam diverges. I use the solver settings from the elbow testcase. Possible problems i thought on: mesh: it is really fine, much too fine (just to be sure) time step: is also set really small (dx=2/40 m, U=1m/s -> dt=0.05 should be sufficient, i set it to 0.01) boundary conditions: inlet with Velocity set to 1 m/s; p at outlet set to 0 Pa. The rest is wall. I checked BC several times, and i find no mistake I include the test case. the case is ready to blockMesh and icoFoam you will see, it diverges after 6 time steps. any hint is really appreciated! Roland |
June 23, 2011, 13:33 |
Roland
I think my test case was not as simple as i thought. The geometry of the tube leads to secondary flows. however, i found out convergence with upwind divScheme is much better.
June 24, 2011, 09:55 |
#3 | |
I think the length of your tube in y direction is very small and you can not impose zeroGradient at the outlet I suggest you, to increase your length ten times of square root of section area |
June 24, 2011, 12:03 |
Roland
mechy, thanks, although i checked the solver conditions several times i payed less attention on the geometry itself. It makes sense that the short tube interferes with the zeroGradient boundary condition. Thanks!
June 25, 2011, 04:28 |
#5 | |
is your problem solved with increasing length of tube ? |
June 27, 2011, 17:02 |
Roland
yes, increasing the length solves the problem. Also i set the time step very low. maybe setting pressure boundary condition instead of velocity at inlet would also help convergence. but it works for me. thanks
Pipe flow with obstacle - HELP | Min | FLUENT | 6 | January 31, 2017 14:28 |
Disturbed flow field at outlet boundary (Multiphase flow through pipe) | Michiel | CFX | 17 | April 21, 2010 10:14 |
simple pipe flow question | arkur | CFX | 1 | July 11, 2008 16:32 |
Pressure Drop - Please Help - Simple Pipe Flow | Joe A. | FLUENT | 2 | April 23, 2007 07:50 |
