July 8, 2010, 15:44 |
Thermophysical models and chemistry models
Hassan Kassem
Rep Power: 17 |
Dear Foamers,
I am modifying rhoReactingFoam solver (OpenFOAM 1.6). I want implement Eddy break-up model. I have no problem with the reaction rate. My main problem is the energy equation source term. I need to access the specieThermo to get Hc() (I think it is the enthalpy of formation). I cannot access it. I think, I am not understand how to access the thermophysical and chemistry models. How are the thermophysical and chemistry models implemented in the solve? How can I access it? |
July 9, 2010, 04:18 |
Christian Lucas
Rep Power: 17 |
Hi hk318i,
I'm not sure if this answers your question because I'm not sure where you need the thermophysical properties (e.g. the solver or the chemistry model template) In the solver (as an expample I use rhoSimpleFoam, where hPsiThemro is used), the thermophsyical model is loaded in the "createFields.H" file. The imported lines are: Info<< "Reading thermophysical properties\n" << endl; autoPtr<basicPsiThermo> pThermo ( basicPsiThermo::New(mesh) ); basicPsiThermo& thermo = pThermo(); now lets say you want to get the enthalpy so the function is: "your variable = thermo.h();" This function can be found in the file (OpenFoam/src/thermophysicalModels/basic/psiThemro/hPsiThemro.H). The function is virtual const volScalarField& h() const { return h_; } These functions could also be in the following files: "basicThemro.H" and "psiBasicThermo.H". So, if you need to get hc in the solver, you first have to make sure that a function like the one above (of course for hc) exist in your themrophysical model. Regards, Christian |
July 9, 2010, 05:26 |
#3 | |
Rep Power: 15 |
hi chris
i've a question to your reply: Quote:
and must i include: #include basicPsiThermo at the beginning? thanks for your help regards marc |
July 9, 2010, 06:19 |
Christian Lucas
Rep Power: 17 |
Hi Marc
the correct term is "volScalarField& h = thermo.h();" (Have a look at the source code of rhoSimpleFoam). The other possibility that might work is: "volScalarField& h = thermo.h_;". However, I think the variable h_ is protected, so it won't work. h_ is the variable(field) used in the thermophysicalProperties and the function h() simply returns h_. You have to include " #include "basicPsiThermo.H" ". In the case of rhoSimpleFoam, you can find the line in the file "rhoSimpleFoam.C" Regards, Christian |
July 9, 2010, 06:21 |
Hassan Kassem
Rep Power: 17 |
Dear Chirs,
rhoReactingFoam uses chemistry model not a thermophysical model as the following; Info<< nl << "Reading thermophysicalProperties" << endl; autoPtr<rhoChemistryModel> pChemistry ( rhoChemistryModel::New(mesh) ); rhoChemistryModel& chemistry = pChemistry(); hsReactionThermo& thermo = chemistry.thermo(); the variable which I am looking for is specieThermo.Hc() my the Thermophysicalproperties is thermoType hsRhoMixtureThermo<reactingMixture<gasThermoPhysic s>>; my chemistryproperties is rhoChemistryModel ODEChemistryModel<gasThermoPhysics>; I have no idea what is gasThermoPhysics? Thanks |
July 9, 2010, 09:40 |
Rep Power: 15 |
hi hassan,
as i understood chemistry is a part of thermophysicalModels, because you need alway a "...Thermo"-file to get T,p, h, etc.. And in the file rhoReactingFoam.C there is #include "hReactionThermo.H" used, which then actually returns hc() 00134 //- Chemical enthalpy [J/kg] 00135 virtual tmp<volScalarField> hc() const = 0; so you can use this regards marc |
July 9, 2010, 10:06 |
Hassan Kassem
Rep Power: 17 |
Dear Marc,
my hReactionThermo.H member functions as the following; // Member functions //- Return the composition of the multi-component mixture virtual basicMultiComponentMixture& composition() = 0; //- Return the composition of the multi-component mixture virtual const basicMultiComponentMixture& composition() const = 0; // Access to thermodynamic state variables //- Enthalpy [J/kg] // Non-const access allowed for transport equations virtual volScalarField& h() { return h_; } //- Enthalpy [J/kg] virtual const volScalarField& h() const { return h_; } //- Update properties virtual void correct() = 0; }; I cannot find hc(). Actually all I need to access the enthalpy of formation to make the energy equ source term which is a function of reaction rate (which I calculated based on my model) and specie enthalpy of formation (like Hc() in specieThermo) Regards Hassan |
July 9, 2010, 14:42 |
M. Mahdi Salehi
Rep Power: 17 |
Just a quick note:
In reactingFoam, a transport equation for "total enthalpy " is solved. Total enthalpy is the sensible enthalpy plus the chemical enthalpy. Thus, the transport equation for this variable does not contain any chemical reaction source term, it is conserved in an adiabatic flame. The chemical reaction source terms are provided for the species mass fractions. Once you get the species mass fractions, the "thermo->correct();" method will calculate the heat of formation and desctruction of different species. |
July 9, 2010, 14:53 |
#9 |
Hassan Kassem
Rep Power: 17 |
I am using OpenFOAM 1.6 which reactingFoam and rhoReactingFoam solve transport equation for sensible enthalpy not the total enthalpy.
Do you think I should use transport equation for total enthalpy instead of sensible enthalpy? |
July 9, 2010, 14:59 |
#10 |
M. Mahdi Salehi
Rep Power: 17 |
This is the hEqn.h in reactingFoam in Openfoam1.6:
{ fvScalarMatrix hEqn ( fvm::ddt(rho, h) + mvConvection->fvmDiv(phi, h) - fvm::laplacian(turbulence->alphaEff(), h) == DpDt ); hEqn.relax(); hEqn.solve(); thermo.correct(); } I do not see any source term, I do not think that it solves for sensible enthalpy, are you sure? |
July 9, 2010, 15:10 |
#11 |
Hassan Kassem
Rep Power: 17 |
My version uses hs with source term as the following;
{ fvScalarMatrix hsEqn ( fvm::ddt(rho, hs) + mvConvection->fvmDiv(phi, hs) - fvm::laplacian(turbulence->alphaEff(), hs) == DpDt + chemistrySh ); hsEqn.relax(); hsEqn.solve(); thermo.correct(); Info<< "T gas min/max = " << min(T).value() << ", " << max(T).value() << endl; } I am using OpenFoam1.6.x which I think it is like OpenFoam 1.7 use sensible enthalpy instead of total enthalpy |
July 9, 2010, 15:18 |
#12 |
M. Mahdi Salehi
Rep Power: 17 |
yes, I downloaded openfoam1.7 and I see now ! it's great, they finally make this. I needed this ! Thanks
July 9, 2010, 15:28 |
#13 |
Hassan Kassem
Rep Power: 17 |
Actually I am little bit confused about using chemistry and thermophysical models. How can I access the data? How can I change the model inside the solver? and what is the "Selector" ? :-O
July 9, 2010, 16:59 |
#14 |
M. Mahdi Salehi
Rep Power: 17 |
For "selecting" you may read this:
http://openfoamwiki.net/index.php/Op...tion_mechanism You cannot have access to everything, unless you change the source code for thermo and chemistry objects. However, you have access to reaction rates, heat release, ... . |
July 9, 2010, 17:19 |
#15 |
Hassan Kassem
Rep Power: 17 |
so I cannot access to something like enthalpy of formation of each specie.
July 11, 2010, 11:31 |
#16 |
Anh Le
Rep Power: 15 |
Hi everyone,
I am trying to simulate a incompressible, laminar fluid flow model with adding temperature field. I used air to be the inlet gas. Assuming that "basicPsiThemo" is only used for compressible, turbulence flow, hence I want to use "basicThermo" model only. And I was writing into the "createFields.H" like that: line 1 Info<< "Reading thermophysical properties\n" << endl; line 2 line 3 autoPtr<basicThermo> pThermo line 4 ( line 5 basicThermo::New(mesh) line 6 ); line 7 basicThermo& thermo = pThermo(); line 8 volScalarField& h = thermo.h(); ... And then compile the code. An error is shown: createFields.H: In function ‘int main(int, char**)’: createFields.H:5: error: no matching function for call to ‘Foam::dictionary::New(Foam::fvMesh&)’ /home/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/dictionary.H:218: note: candidates are: static Foam::autoPtr<Foam::dictionary> Foam::dictionary::New(Foam::Istream&) So what is the right one I have to declare? What does it mean about the line 5? And how can I check the declaration of basicThermo mode? Please give me a hint? |
July 12, 2010, 08:32 |
#17 |
Hassan Kassem
Rep Power: 17 |
Dear Anh,
I am new OpenFoam user and I am not fully aware about this problem. As I know you cannot basicThermo like as you mentioned because basicThermo class does not have a selector function like basicpsiThermo. |
July 12, 2010, 15:08 |
#18 |
Anh Le
Rep Power: 15 |
Thanks. I got that. However, what is basicThermo function to use? Can basicpsiThermo quantities be used for incompressible, laminar flow? If not, what is the right one?
July 12, 2010, 15:47 |
#19 |
Hassan Kassem
Rep Power: 17 |
you can check the openFoamwiki below likw which descripe how to add temperature to icoFoam solver.
http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam |
July 15, 2010, 06:09 |
#20 |
Hassan Kassem
Rep Power: 17 |
Dear All,
Anyone knows what is the CompType in ODEChemistryModel and other chemistry models? I am still looking how to access the enthalpy of formation of each species. any ideas? Regards, Hassan |
Equilibrium Reaction Rates/Gas Chemistry | Greg Perkins | FLUENT | 6 | January 6, 2017 02:59 |
