Extending Libraries
hi everyone,
The OpenFOAM software includes over 80 shared libraries containing a range of functionality for numerics, linear solvers, modelling, meshing, post-processing, etc. Libraries are designed to be conveniently extended with the following feature helping to make the task easier. Dynamic linking of libraries When a new library is created, it does not need to be linked directly into applications wishing to use its functionality. Instead, the user can dynamically link the library at run-time, through a setting in the case controlDict file. I want to create a new scheme or implementation of existing scheme in openfoam, can anybody applied the above method, if so please write the procedure for doing so,thanks in advans, Regards, |
