Gradient at face center of a scalar volume field
Old   June 28, 2011, 12:33
Default Gradient at face center of a scalar volume field
Praveen. C
praveen is on a distinguished road
Hello
How do I get the gradient vector at the face centers, given a scalar volume field ?
praveen is offline   Reply With Quote
Old   June 28, 2011, 12:49
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Praveen, it's usually achieved by a linear interpolation of fvc::grad(field) at faces. The following is an example taken from:
src/transportModels/interfaceProperties/interfaceProperties.C
00113     // Cell gradient of alpha
00114     const volVectorField gradAlpha(fvc::grad(alpha1_));
00115
00116     // Interpolated face-gradient of alpha
00117     surfaceVectorField gradAlphaf(fvc::interpolate(gradAlpha));
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   June 29, 2011, 00:02
Praveen. C
Thanks. So I guess there is no available scheme to directly obtain face gradients by applying a green-gauss or least-squares scheme centered at the face-center.
Old   June 29, 2011, 02:20
Bernhard
Bernhard is on a distinguished road
What do you mean by directly? You set the discretization of grad(alpha) and interpolate(gradAlpha) in fvSchemes as you're used to.
Bernhard is offline   Reply With Quote
Old   June 29, 2011, 02:23
Praveen. C
Without interpolation. Define a volume around the face center and apply green-gauss theorem. Or least squares method.
Old   June 30, 2011, 08:00
Bernhard
If you're referring to a staggered kind of mesh, I don't think such a thing is possible in OpenFOAM
[blockMesh] Internal walls of zero thickness anger OpenFOAM Meshing & Mesh Conversion 23 February 6, 2020 18:25
why i can't split a real volume with a virtual face. George Chen 28 Main CFD Forum 0 March 8, 2010 03:41
How to compute gradient for non-orthogonal grids? Paul Hsieh Main CFD Forum 3 November 11, 2003 04:52
Question on Face Temperature Gradient Tomasz Didenko FLUENT 1 June 27, 2003 04:30
calculate cell volume, center...? Paul Main CFD Forum 5 June 21, 2003 12:55
