[swak4Foam] OpenFOAM v2.0 and groovyBC
Old   June 23, 2011, 08:19
Default OpenFOAM v2.0 and groovyBC
steph79 is on a distinguished road
I can't seem to get groovyBC to work with OpenFOAM 2.0. I had it working with 1.7, even though it isn't listed as compatible on http://openfoamwiki.net/index.php/Contrib_groovyBC so I presume it should work with 2.0.
Here's what I get after running wmake (not as sudo);
touch: cannot touch `Make/linux64GccDPOpt/dontIncludeDeps': Permission denied
SOURCE=PatchValueExpressionDriver.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPOpt -I/opt/openfoam200/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam200/src/OpenFOAM/lnInclude -I/opt/openfoam200/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/PatchValueExpressionDriver.o
In file included from Make/linux64GccDPOpt/location.hh:44,
from PatchValueExpressionParser.tab.hh:65,
from PatchValueExpressionDriver.H:59,
from PatchValueExpressionDriver.C:34:
position.hh: In function ‘bool pve:perator==(const pve:osition&, const pve:osition&)’:
position.hh:136: warning: suggest parentheses around ‘&&’ within ‘||’
PatchValueExpressionDriver.C: In member function ‘void Foam::PatchValueExpressionDriver::error(const pve::location&, const std::string&)’:
PatchValueExpressionDriver.C:192: error: expected unqualified-id before ‘::’ token
PatchValueExpressionDriver.C:192: error: expected ‘;’ before ‘::’ token
PatchValueExpressionDriver.C: In member function ‘void Foam::PatchValueExpressionDriver::error(const std::string&)’:
PatchValueExpressionDriver.C:202: error: expected unqualified-id before ‘::’ token
PatchValueExpressionDriver.C:202: error: expected ‘;’ before ‘::’ token
make: *** [Make/linux64GccDPOpt/PatchValueExpressionDriver.o] Error 1
Any suggestions? Thanks.
steph79 is offline   Reply With Quote
Old   June 23, 2011, 22:25
Assistant Moderator
Bernhard Gschaider
Originally Posted by steph79 View Post
<error message snipped>
That is the kind of problem that is to be expected with a major release.
I'll have a look at this once I'm back from vacation.
If you want to be sure that I remember this and want to be updated on the progress of the port open a ticket at
http://sourceforge.net/apps/mantisbt...?page_number=1
Bernhard
Old   June 23, 2011, 22:39
Assistant Moderator
Bernhard Gschaider
Quick fix: remove the Foam:: in these two lines
Bernhard
PS: Stuff from the other posting still applies
Old   June 27, 2011, 07:18
Bernhard
Thanks I removed "Foam::" from lines 192 and 202 in the PatchValueExpressionDriver.C source file respectively and then tried wmake libso with the following error message;
/opt/openfoam200/wmake/scripts/addCompile: 53: cannot create PatchValueExpressionDriver.dep: Permission denied
/opt/openfoam200/wmake/scripts/addCompile: 57: cannot create PatchValueExpressionDriver.dep: Permission denied
/opt/openfoam200/wmake/scripts/addCompile: 59: cannot create PatchValueExpressionDriver.dep: Permission denied
/opt/openfoam200/wmake/scripts/addCompile: 60: cannot create PatchValueExpressionDriver.dep: Permission denied
/opt/openfoam200/wmake/scripts/addCompile: 61: cannot create PatchValueExpressionDriver.dep: Permission denied
/opt/openfoam200/wmake/scripts/addCompile: 62: cannot create PatchValueExpressionDriver.dep: Permission denied
Making dependency list for source file PatchValueExpressionDriver.C
make: *** [PatchValueExpressionDriver.dep] Error 2
Since it says permission denied I tried as sudo but then it can't understand wmake.
Old   June 27, 2011, 07:56
Assistant Moderator
Bernhard Gschaider
This "permission denied" is an OS-problem. Probably you don't have write access to the directories in question.
Bernhard
Old   June 27, 2011, 11:03
Michael B Martell Jr
theory37 is on a distinguished road
Adam, where did you place the groovyBCs source files?
Mike
theory37 is offline   Reply With Quote
Old   June 27, 2011, 16:43
Mike
/~/OpenFOAM/groovyBC
where /~/OpenFOAM is the directory I use to store and execute my cases inside my home folder.
Old   July 14, 2011, 21:30
Ulisses
ulisses is on a distinguished road
Bernhard
Thanks Bernhard !!!!
ulisses is offline   Reply With Quote
[swak4Foam] groovyBC in openFoam 230 imani OpenFOAM Community Contributions 19 April 6, 2015 07:25
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
[swak4Foam] OpenFOAM 1.6 and 1.7 with interFoam, groovyBC give different strange results Arnoldinho OpenFOAM Community Contributions 7 December 9, 2010 16:29
[swak4Foam] wmake groovyBC in OpenFOAM 1.7 ? randomid OpenFOAM Community Contributions 1 August 27, 2010 05:15
[swak4Foam] how to compile groovyBC to OpenFoam v1.6? tamsilian OpenFOAM Community Contributions 1 May 27, 2010 03:15
