2D simpleFoam simulation gets stuck - no error - problem with boundaries?
Old   July 13, 2011, 05:14
Default 2D simpleFoam simulation gets stuck - no error - problem with boundaries?
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Hi all;
trying to run a simple 2D circular cylinder.
I have already run that but I got a 3D resulting field so I slightly changed the boundary conditions and now the simulation gets stuck without any error at:
Time = 1
smoothSolver:  Solving for Ux, Initial residual = 0.407396, Final residual = 0.0155929, No Iterations 3
smoothSolver:  Solving for Uy, Initial residual = 0.485038, Final residual = 0.0173646, No Iterations 3
What you think could be the problem?
Maybe something related to my boundaries?
Thank you!
Lorenzo
lovecraft22 is offline   Reply With Quote
Old   July 13, 2011, 05:16
lore
Update: I think it blows up and I get a floating point excepion…
Any help would be really appreciated!
Old   July 13, 2011, 05:37
The True
Eren10 is on a distinguished road
set-up normal files for BC , especially for U and p. I dont see why you are using complicates structure of the files, look to the tutorials
Eren10 is offline   Reply With Quote
Old   July 13, 2011, 07:32
lore
Thank you Eren.
What do you mean with "Complicate file structure"?
Old   July 13, 2011, 12:59
lore
Ok, I simplified the boundary conditions for U and p (which I copied from the motorbike tutorial and that's why they were a little bit complicated).
Now, what should I set for the turbulence model (K-e) conditions?
Old   July 13, 2011, 16:37
lore
Eventually I managed to solve the case but I got a 3D solution instead of a 2D one, as you can see from the pressure plot on the surface:
What may the problem be?
Thank you!
Old   July 14, 2011, 09:58
The True
you want to simulate a 2D, so x and y . In the z direction only a one cell is required. if we asume x y forms the circular shape of the cylinder, than the domains parallel to the x- y plane should be empty.
Old   July 14, 2011, 10:14
lore
Tank you eren. If you look at my case directory you'll see that I already have only ove cell in z direction and both the planes perpendicular to the z-axis are already set as empty...
Old   July 14, 2011, 10:28
The True
I have no experience with the openfoam's way of generating the object, I am using an other program for mesh. so I cant help you. But make the distance in the z direction very small. but if that is oke, make a paint figure of the inlet outlet conditions etc.. in 2D, than we can check the BC.
Old   July 14, 2011, 12:05
lore
Inlet and outlet conditions (e.g. pressure) are perfectly 2D…
Old   July 15, 2011, 13:51
lore
I think I'll open another topic for this problem, since it's quite different from the one I started this topic for.
FSI TWO-WAY SIMULATION Smagmon CFX 1 March 6, 2009 13:24
Overflow problem in steady simulation ReeKo CFX 11 October 8, 2008 17:57
Tank simulation: Boundaries Humberto Avila FLUENT 2 May 17, 2006 14:18
Fire simulation using FDS from NIST Jens Main CFD Forum 1 January 22, 2004 01:53
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 10:06
