PorousZone using Mesh imported from Salome
Old   July 29, 2011, 03:12
Default PorousZone using Mesh imported from Salome
Raph Raggatt
Rapha is on a distinguished road
I have created a Mesh in Salome pre-processing software and exported it into OpenFOAM using the ideasUnvToFoam process. I have designed it in 6 separate sections then built a compound mesh with all sections together, each defined by their respective group geometries such as inlet, outlet, etc.
However, I am trying to use the rhoPorousMRFSimpleFoam case with this mesh. When I load it up with all the various parameters, I get stuck when it asks for
--> FOAM FATAL ERROR:
cannot find porous cellZone Stone_1
From function Foam:orousZone:orousZone(const keyType&, const fvMesh&, const dictionary&)
in file cfdTools/general/porousMedia/porousZone.C at line 94.
The problem is when I've exported the Mesh from salome, no cellZones are created so I can't modify them for this case.
If someone could tell me how either to export the mesh from Salome to include cellZones or how to modify the porousZone input without the need for cellZones, I would be really grateful.
Thanks in advance
Rapha is offline   Reply With Quote
Old   October 18, 2011, 07:51
Raph Raggatt
If anyone wants to know the answer of how to create a cellzone using Salome. Simply select the regions from the "Create Groups from Geometry" under the volume element. Add these in the Mesh section, then export.
Old   November 8, 2013, 06:03
Nickolas P
NickolasPl is on a distinguished road
Hello Raph,
I did exactly the same thing on a case with porous zone from SALOME using ideasUnvToFoam but with no luck. It gives me the following error:
From function HashTable<T, Key, Hash>:perator[](const Key&)
in file /home/sarris/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude/HashTableI.H at line 110.
The problem is probably on the "Group on Volume" from SALOME. Because, when I exported the mesh from SALOME to OpenFOAM without the porous zone, the export was done ok with no problem. Any reccomendations?
I would greatly appreciate your help.
Regards,
Nickolas
NickolasPl is offline   Reply With Quote
Old   November 12, 2013, 09:10
nsf
Nicolas Edh
nsf is on a distinguished road
Originally Posted by NickolasPl View Post
Hello Raph,
Regards,
Nickolas
Hi Nickolas,
If you haven't solved your problem yet you could try a python script I created. See my post at
http://www.cfd-online.com/Forums/ope...-openfoam.html
It supports cellZones, just add all domains as separate groups and it should work. Let me know if you run in to problems.
Best regards
Nicolas
nsf is offline   Reply With Quote
Old   November 12, 2013, 11:57
Nickolas P
Hi Nicolas,
I downloaded your utility and loaded the script in SALOME. I get the following error message when try to run it:
p, li { white-space: pre-wrap; } File "<input>", line 1, in <module>
File "/home/sarris/OpenFOAM/Nickolas/Melt_Impr_BATES/salomeToOpenFOAM-master/salomeToOpenFOAM.py", line 46, in <module>
from salome.smesh import smeshBuilder
ImportError: cannot import name smeshBuilder
Do you know which might be the reason for such an error?
Thanks in advacne!
Nickolas
porouszone salome
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 00:27
Converting Salome hybrid mesh to OpenFOAM Arnoldinho OpenFOAM 4 March 28, 2012 10:24
Mesh conversion exits prematurely (Salome to OF) DMcP OpenFOAM 0 July 14, 2011 02:07
Imported ICEM mesh has additional body in the mesh Procyon CFX 1 January 27, 2011 16:21
SimpleFoam error with mesh imported from salome matteo OpenFOAM Running, Solving & CFD 9 January 2, 2008 04:04
