wmake error while adding T to icoFoam
Like Tree2Likes
  • 1 Post By falsafioon
Old   August 1, 2011, 17:38
Default wmake error while adding T to icoFoam
Brad Maeg
boongsin12 is on a distinguished road
I am trying to modify currently available solver in OpenFoam. http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam So, I found a great tutorial on how to implement temperature into icoFoam, which is currently available.
I am having a little trouble wmake-ing the solver. After following the tutorial in detail, I was not able to compile the solver. Instead, the following came up as error. I only see one error and that is colored in red. I would like some insights from those who have already tried this particular tutorial or have implemented their own solver.
By the way, I am using OpenFoam 2.0, the newest.
Thanks so much for your time.
root@brad-ThinkPad-X200:/opt/openfoam200/applications/solvers/incompressible/my_icoFoam# wmake
SOURCE=my_icoFoam.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam200/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam200/src/OpenFOAM/lnInclude -I/opt/openfoam200/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/my_icoFoam.o
my_icoFoam.C: In function ‘int main(int, char**)’:
my_icoFoam.C:104:2: error: no matching function for call to ‘Foam::fvMatrix<double>::fvMatrix(Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >)’
/opt/openfoam200/src/finiteVolume/lnInclude/fvMatrix.C:418:1: note: candidates are: Foam::fvMatrix<Type>::fvMatrix(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, Foam::Istream&) [with Type = double]
/opt/openfoam200/src/finiteVolume/lnInclude/fvMatrix.C:361:1: note:                 Foam::fvMatrix<Type>::fvMatrix(const Foam::tmp<Foam::fvMatrix<Type> >&) [with Type = double]
/opt/openfoam200/src/finiteVolume/lnInclude/fvMatrix.C:330:1: note:                 Foam::fvMatrix<Type>::fvMatrix(const Foam::fvMatrix<Type>&) [with Type = double]
/opt/openfoam200/src/finiteVolume/lnInclude/fvMatrix.C:273:1: note:                 Foam::fvMatrix<Type>::fvMatrix(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::dimensionSet&) [with Type = double]
/opt/openfoam200/src/finiteVolume/lnInclude/readPISOControls.H:3:15: warning: unused variable ‘nOuterCorr’
/opt/openfoam200/src/finiteVolume/lnInclude/readPISOControls.H:12:16: warning: unused variable ‘momentumPredictor’
/opt/openfoam200/src/finiteVolume/lnInclude/readPISOControls.H:15:16: warning: unused variable ‘transonic’
make: *** [Make/linux64GccDPOpt/my_icoFoam.o] Error 1
boongsin12 is offline   Reply With Quote
Old   August 1, 2011, 18:38
Brad Maeg
Ah ha,
I figured it out. Simple mistake on my part.
Old   August 10, 2011, 03:49
Tibor Nyers
Toorop is on a distinguished road
Hi Brad,
same problem here, but can't crack it. Could you please explain the solution!
Toorop is offline   Reply With Quote
Old   August 17, 2011, 07:34
Tibor Nyers
To finish this off!
Another freaking blind copy-paste error. In createFields.H:
volScalarField T
    IOobject
        "T",
        runTime.timeName(),
        mesh,
        IOobject::MUST_READ,
        IOobject::AUTO_WRITE
    mesh
Old   November 1, 2012, 13:13
Mehdi
falsafioon is on a distinguished road
Hi everybody
I'm new in OpenFOAM and C++ and I'm trying to modify an available solver to solve a cross derivative equation. But unfortunately I'm getting the similar error while wmake-ing the solver:
no matching function for call to ‘Foam::fvMatrix<Foam::Vector<double> >
The modified solver is:
#include "fvCFD.H"
int main(int argc, char *argv[])
       #include "setRootCase.H"
       #include "createTime.H"
       #include "createMesh.H"
       #include "createFields.H"
       Info<< "\nStarting time loop\n" << endl;
       while (runTime.loop())
               Info<< "Time = " << runTime.timeName() << nl << endl;
        fvVectorMatrix TEqn
                  (fvc::grad(phi) & vector(1,0,0)))
        solve( TEqn ==  -s);
            Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl;
            Info<< "Estimating error in scalar poisson equation" << endl;
        runTime.write();
              Info<< endl;
          } // Fin Error
          Info<< "End-loop\n" << endl;
          return 0;
Does anybody know how can I fix the problem?
Please excuse me because of my poor English.
Thank you for your help
Kummi likes this.
falsafioon is offline   Reply With Quote
Old   November 2, 2012, 06:25
Nima Samkhaniani
nimasam is on a distinguished road
fvVectorMatrix TEqn
at least two errors:
1) extra ")"
2) inner product of two vector is an Scalar, so it should be "fvScalarMatrix"
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   November 2, 2012, 13:19
Mehdi
Thank you for your consideration
But unfortunately I'm still receiving the same error message even after correcting the mentioned errors. The new one is:
fvScalarMatrix TEqn
But I think the problem is somewhere else because when I change the code like to the following it works properly:
fvScalarMatrix TEqn
                  fvm::laplacian(phi)
                - fvm::laplacian(phi)
Any help?
Old   November 2, 2012, 13:45
Nima Samkhaniani
uhum
thats right, because you use "fvc"
fvc convert a field to another field, it does not make any matrix
Old   November 5, 2012, 17:03
Mehdi
Thank you Nima
yes , you are right, but it's still supposed to work because both sides are scalar fields. So why doesn't it work?
Let's talk about something simpler. Even following code couldn't be compiled:
        fvScalarMatrix TEqn
               fvc::grad(phi)
        solve( TEqn ==  -s);
what's the reason?
Old   November 6, 2012, 02:04
Nima Samkhaniani
because fvc::grad(phi) does not make the matrix of coefficient, it is a known and definite variable, it is like you put for example a variable T = s , which both T and s has value
Old   November 6, 2012, 13:56
Mehdi
I appreciate your help Nima, I found the problem
Actually I was trying to solve Winslow equation by OpenFOAM:
αxξξ − 2βxξη + γxηη = 0
but it seems that it's impossible.
Does anybody know if there is a way to solve it by OpenFOAM?
Old   November 23, 2012, 19:34
Mehdi
Hi everybody
any idea to handle cross derivatives (like xξη) in OpenFOAM?
Kummi likes this.
compile, error, icofoam, implementation, wmake
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Problems Installing OF 1.6 32 bit bucksfan OpenFOAM Installation 19 August 4, 2009 01:36
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 04:41
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 21:45
[OpenFOAM] ParaFoam error message joey ParaView 1 October 2, 2006 13:28
