January 8, 2013, 16:25 |
reisiduals in simplefoam
Rep Power: 14 |
Hi Foamers
I am working with a unstedy version of simpleFoam. The vale of residuals calculated using the "initialResidual()" command (like PeqnResidual = pEqn.solve().initialResidual()for pressure) is different from the value of final residuals reported in the log file (ex. DICPCG: Solving for p, Initial residual = 0.00111906, Final residual = 9.36366e-07, No Iterations 116). Shouldn't they be the same? I mean, does the initialResidual() gives the final residual for each parameter given by the linear solver? |
interFoam vs. simpleFoam channel flow comparison | DanM | OpenFOAM Running, Solving & CFD | 12 | January 31, 2020 15:26 |
Laminar simpleFoam and inviscid simpleFoam | herenger | OpenFOAM Running, Solving & CFD | 7 | July 11, 2013 06:27 |
Experimental data vs SimpleFoam sphere test case : Cd do not match | alsdia | OpenFOAM Verification & Validation | 1 | November 2, 2012 05:37 |
Trying to run a benchmark case with simpleFoam | spsb | OpenFOAM | 3 | February 24, 2012 09:07 |
Naca0012 k-e mpirun gives fpe whereas simpleFoam not | Pierpaolo | OpenFOAM | 1 | May 8, 2010 03:08 |
