compile problem of paraview 3.8.0 conjucting with Qt4.7.3
Old   August 17, 2011, 23:38
Default compile problem of paraview 3.8.0 conjucting with Qt4.7.3
zdong
abbott.hn is on a distinguished road
hello everyone .
according to the openfoam 11.4 install guide, when i type ./makeParaview in the konsole, i encounted i problem like this:
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
QT_QTASSISTANTCLIENT_INCLUDE_DIR (ADVANCED)
used as include directory in directory /usr/local/OpenFOAM/ThirdParty-1.7.1/paraview-3.8.0/Qt/ApplicationComponents
-- Configuring incomplete, errors occurred!
by the way , i have qt 4.7.3 library in my computer.
could anyone help me out or show me where i can find the reference online ?
thanks a lot..
abbott.hn is offline   Reply With Quote
Old   August 18, 2011, 06:22
Retired Super Moderator
Bruno Santos
Greetings abbott.hn and welcome to the forum!
Mmm, ParaView 3.8 doesn't like very much Qt 4.7 There have been some issues with it in the past, so my suggestion is to follow the instructions from this blog post of mine: Building ParaView 3.8.0 with custom Qt 4.6.3
If you still want to use Qt 4.7.3, then check the packages that should be installed, which are shown here: http://www.openfoam.com/download/source.php#x5-21000
Best regards and good luck!
Bruno
Old   August 23, 2011, 05:25
Default i have solved this problem
zdong
Bruno
hello bruno. you are so kind ..
I have already solved the problem by downlodading the latest Openfoam .the paraview in this package got an version 3.10,and it can be compiled successfully with qt4.7.3 .
appreciate you so much.
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
[OpenFOAM] ParaView Problem with dsmcFoam xbook ParaView 4 February 14, 2014 01:09
[OpenFOAM] paraview split screen problem ziemowitzima ParaView 1 March 16, 2011 14:07
Qt version of Paraview 3.8.0 in OpenFOAM 1.7 waynezw0618 OpenFOAM Installation 10 March 3, 2011 08:53
Compile Problem Leigh FLUENT 3 July 28, 2006 05:31
