Turbulent heat flux through the wall
Old   January 24, 2012, 20:32
Default Turbulent heat flux through the wall
Yuri Feldman
feldy77 is on a distinguished road
Dear forum,
I am really confused about how I should compute heat flux through the static boundary in the presence of turbulent incompressible flow if I use the basic k-e model. According to the heat transfer theory
Q''=(k_lam+k_turb)(dT/dn), where k_lam is a some constant value of a certain fluid and k_turb=cp*miu_t/Pr_t. It looks like everything is clear : cp is known, the commonly used value of Pr_t is 0.85, miu_t is calculated from k-e model. The twist is that the boundary value of miu_t (niu_t for incompressible flow) is set to zero (I am talking about buouantBoussinesqPimpleFoam tutorial for hotRoom). The same is done for the boundary value of miu_t in Fluent. Then it is completely unclear what is the difference between calculating of heat flux for laminar and turbulent flows.
I will be very grateful if somebody clarifies this issue,
many thanks, Yuri
feldy77 is offline   Reply With Quote
Old   January 25, 2012, 13:34
Yuri Feldman
please anybody can say his opinion,
I really need your help
Old   January 25, 2012, 17:50
Kai
kaifu is on a distinguished road
k_turb
Originally Posted by feldy77 View Post
Dear forum,
many thanks, Yuri
I dont see any problems inside. As you said, Q''=(k_lam+k_turb)(dT/dn). if k_turb=0 then Q''=k_lam dT/dn.
And the temperature
relies on the turbulent model you included although you will have the same gradient at the wall. I am sure temperature in the bulk is totally different between laminar and turbulent flows due to the different heat transfer coeff in the bulk.
Kai
kaifu is offline   Reply With Quote
Old   January 25, 2012, 18:04
Yuri Feldman
Kai,
Thank you for your reply. Maybe you can explain me then, why the openFoam utility wallHeatTransfer utilizes alafaeff whcich consists of turbulent amd laminar components and not jus uses the laminar component only
Many thanks, yuri
Old   January 25, 2012, 18:21
Kai
Kai,
Many thanks, yuri
It is all dependent on the expectation you have. The wall viscosity should be modelled actually. I can only say that the treatment of zero wall viscosity is rather crude. If you would like to model wall viscosity, plz refer to the file "wallViscosity.H" in the solver of bubbleFoam.
Kai
Old   March 6, 2012, 07:33
Goutam Saha
Goutam is on a distinguished road
Dear forum,
many thanks, Yuri
Dear Yuri, did you able to solve this problem? I am facing same problem.
Looking forward to see your reply.
Goutam is offline   Reply With Quote
Old   March 6, 2012, 13:33
niaz's Avatar
A_R
niaz is on a distinguished road
Dear Foamers
for k-epsilon model, you must use wall-function for nut.
and without it, the solution is not acceptable.
niaz is offline   Reply With Quote
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
HELP - Wall Heat Flux CFX Karkoura CFX 5 March 29, 2011 12:44
calculation of wall heat flux in CHT richard CFX 1 July 23, 2009 09:00
Heat flux and k-e wall boundary conditions Blob CFX 4 June 8, 2009 05:10
WALL HEAT FLUX tommy CFX 0 December 20, 2005 12:42
