August 31, 2011, 15:01 |
problems with .msh mesh
Paulo Victor Soares e Silva
Rep Power: 14 |
I'm having trouble converting a mesh. msh . In the terminal window of my case, when I type the command gmshToFoam, it appears: -> FOAM FATAL IO ERROR: wrong token type - expected word found on line 0 the punctuation token '(' file: IStringStream.sourceFile at line 0. From function operator>> (istream &, & word) in file primitives / strings / word / wordIO.C at line 76. FOAM exiting what it means and how can I solve this problem? I am new to OpenFoam. Thank you. |
Display Modes | |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[ANSYS Meshing] First layter thickness on mesh causing problems | Rik102 | ANSYS Meshing & Geometry | 0 | November 4, 2016 10:51 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
[Commercial meshers] Problems with ANSYS mesh conversion | tdog | OpenFOAM Meshing & Mesh Conversion | 1 | March 31, 2016 18:36 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
