August 16, 2011, 09:14 |
Boundary layer in OpenFOAM
Jan Goebel
Rep Power: 17 |
Hello j-avdeev,
with blockmesh you can create graded mesh blocks (according to chpt. 2.1.6. in Users guide). If you want to create a boundary layer, it may be useful to divide up the blocks in graded and non graded cells according to the attached example. greets, Jan |
September 19, 2011, 06:27 |
Prism layers in openFOAM
Jan Goebel
Rep Power: 17 |
Hi j-avdeev,
This model (see attached files) I created with a python script. With python you can do parametric modelling and it`s much easier than editing the blockMeshDict by hand. For 3D- boundary layer you can use salome (www.salome-platform.org) greets, Jan Last edited by jango; September 19, 2011 at 06:48. Reason: forgotten attachments |
September 23, 2011, 16:38 |
Avdeev Evgeniy
Rep Power: 21 |
Also connected theoretical question -
how you choose sufficient count of boundary layers? and mesh frequency? Are you just use Courant number (as written in User Guide) or something else? |
September 25, 2011, 05:43 |
#6 | |
Jan Goebel
Rep Power: 17 |
that strongly depends on your desired results. In the theorical way you can do it as written in UG. In practical experience it`s mostly the case, that you approximately estimate the number of cells without boundary layer and set up a model with a coarse mesh in a parametric way. Making sure, the model works, you simply change the parameters for mesh refinement and boundary layers. If you`re not interested in near wall results at some parts of the model and you don`t have heated walls or something, you can simply calculate the model without boundary layers at this regions. have fun trying it and a nice weekend, Jan |
[ICEM] Creation of hexa dominant mesh and prism layer | gnuboard | ANSYS Meshing & Geometry | 7 | January 11, 2018 04:13 |
[snappyHexMesh] Boundary layer generation problems | ivan_cozza | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2010 13:47 |
[ICEM] Auto prism layer growth to unity | siw | ANSYS Meshing & Geometry | 5 | August 23, 2010 16:40 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
