November 9, 2011, 08:58 |
Compressible flow
Rep Power: 14 |
Hello there.
Well, I'm new with OpenFOAM and for the past month I've been using it to perform some simulations. To do so, I took icoFoam and added a second phase to the simulation obtaining a velocity field for each phase. Later on I also added temperature transport for both phases. Until now I've been simulating only incompressible fluids, but now I need to do the same with compressible ones. Until now the fluids I was using had constant densities, given by a scalar value, but now I want to change this so I can assign them a variable value given by an equation, such as: "Pressure/(R*Temperature)", being R the gas universal constant. As you can see the density would then depend on the pressure, characterizing a compressible flow. What modifications should I perform in my modified icoFoam so it would be able to correctly simulate this situation??? Or would it be better to use another built-in solver? Thanks a lot |
November 10, 2011, 04:41 |
Disabled
Rep Power: 15 |
Why don't you try rhoCentralFoam or another compressible solver?
I am not an expert in this field but it sounds like you will need many modifications |
November 10, 2011, 08:12 |
Vesselin Krastev
Rep Power: 20 |
Use rhoPimpleFoam or rhoPisoFoam and run them in laminar mode (if you need a laminar solution)
V. |
Compressible flow, no data at the outlet | mireis | FLUENT | 6 | September 3, 2015 02:10 |
Natural Convection using Compressible Flow (chtMultiRegionFOAM) | msarkar | OpenFOAM | 2 | September 7, 2010 00:13 |
help with compressible flow BC's (need subsonic flow) | meangreen | Main CFD Forum | 5 | July 24, 2010 13:16 |
Compressible Fluid Flow in COMSOL Multiphysics | BBG | COMSOL | 1 | November 19, 2008 14:05 |
Solving unsteady compressible low speed flow | atit | Main CFD Forum | 8 | July 31, 2000 13:19 |
