Error with modified interFoam solver
Old   September 27, 2011, 09:00
Default Error with modified interFoam solver
Robert Maier
robertmaier9 is on a distinguished road
Hi all,
I'm having a problem with a version of interFoam that I modified. The error message is pasted below. I can't get my head around what the problem is. I get it at the end of the while(runTime.run()) loop in the solver where UEqn, PISO, etc. run after the first go at it. Might anyone have any suggestions as to where to look next?
Thanks!
#0  Foam::error::printStack(Foam::Ostream&) in "/usr/local/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#1  Foam::sigSegv::sigSegvHandler(int) in "/usr/local/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#2  ?? in "/lib64/libc.so.6"
#3  Foam::primitiveEntry::~primitiveEntry() in "/usr/local/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#4  Foam::dictionary::~dictionary() in "/usr/local/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#5  main in "/home/rm/OpenFOAM/rm-1.6.x/applications/bin/linux64GccDPOpt/interFoamHeatTransferVar"
#6  __libc_start_main in "/lib64/libc.so.6"
#7  __gxx_personality_v0 in "/home/rm/OpenFOAM/rm-1.6.x/applications/bin/linux64GccDPOpt/interFoamHeatTransferVar"
Speicherzugriffsfehler
robertmaier9 is offline   Reply With Quote
Old   September 27, 2011, 09:05
Bernhard
Bernhard is on a distinguished road
Can you show some more of your logfile? What modifications did you make? Did the case run without these modifications?
Bernhard is offline   Reply With Quote
Old   September 27, 2011, 10:55
Robert Maier
Thanks for the quick response! I have made some extensive changes. I have added heat transfer into interFoam, which had worked before. Then I added a new method of calculating the heat transfer coefficient at the interface as a subroutine in alphaEqnSubCycle. The first implementation of the internal cells worked. Then I started playing with values on the boundaries, and this is where things stopped working.
I have run this case with different "generations" of this solver, but the most recent version is giving me trouble.
It's safe to say, that I have changed a lot, and one loses a bit of oversight when this happens. I'm going to keep on chuggin' away. Any help would be most excellent!
Thanks.
|  \\    /   O peration     | Version:  1.6.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 1.6.x-f8fd22081aa7
Exec   : interFoamHeatTransferVar
Date   : Sep 27 2011
Time   : 14:56:01
Host   : hpc-cluster
PID    : 20198
Case   :  /home/CFD_Filmgruppe/HeatTransferAndMarangoni_Simulations/Studienarbeit_Robert_Maier/TestCases/TestCase_2D/k_as_function_of_a_B/Shell/Solution1x1Mesh/a10/b85
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
Reading g
Reading transportProperties
Reading field p
Reading field alpha1
Reading field U
Reading field T
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Read heat capacity and conductivity
time step continuity errors : sum local = 0, global = 0, cumulative = 0
DICPCG:  Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
Courant Number mean: 0 max: 0
Starting time loop
Time = 0.001
MULES: Solving for alpha1
Liquid phase volume fraction = 0.1  Min(alpha1) = 0  Max(alpha1) = 1
Begin calculateK.H
Initialize all other values
Start loop
Start localAlpha
Inside if loop 0
Inside if loop 1
Inside if loop 2
Inside if loop 3
Enter boundary faces loop
(0 0 -1)
(0 0 1)
(0.1 0 0)
Up to here 4
(-0.1 0 0)
Up to here 4
(0 0.1 0)
coeffb1 =1.6484
coeffb2 =-0.1368
coeffb3 =-0.2526
Done with loop
Calculating the corresponding heat transfer coefficient
alphaSubCycle is now finished
DILUPBiCG:  Solving for T, Initial residual = 1, Final residual = 0, No Iterations 1
ExecutionTime = 0.05 s  ClockTime = 0 s
Old   September 30, 2011, 06:26
Robert Maier
I have narrowed down the problem. The problem occurs when I try to save a value to the boundary fields. I have created a coefficient with the name f1 which is of class surfaceScalarField. When I comment out the follow bit of code, the solver runs. Only when I keep the line(s) active, does the error occur.
f1.boundaryField()[patchID][facei] = f1temp;
Here, f1temp is a double between 0 and 1.
There is no problem with saving it to an internal face as in the next line of code. Only with the boundary.
[CODE]f1[facei] = f1temp;[\CODE]
I've run it on a single cell as well as multiple cells. The error I get for the multiple cells (4x4) is as follows.
DILUPBiCG:  Solving for T, Initial residual = 1, Final residual = 7.85363558977e-09, No Iterations 4
ExecutionTime = 0.06 s  ClockTime = 0 s
*** glibc detected *** interFoamHeatTransferBlending: double free or corruption (!prev): 0x000000000068e260 ***
======= Backtrace: =========
/lib64/libc.so.6[0x2ae6a3c0876e]
/lib64/libc.so.6(__libc_free+0x6c)[0x2ae6a3c09ebc]
/usr/local/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam22calculatedFvPatchFieldINS_6VectorIdEEED0Ev+0x35)[0x2ae6a23639b5]
interFoamHeatTransferBlending(_ZN4Foam14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEED1Ev+0x84)[0x430914]
interFoamHeatTransferBlending[0x41d891]
/lib64/libc.so.6(__libc_start_main+0xf4)[0x2ae6a3bba304]
interFoamHeatTransferBlending(__gxx_personality_v0+0xf9)[0x415a09]
======= Memory map: ========
00400000-0046f000 r-xp 00000000 08:11 2159478628                         /home/rm/OpenFOAM/rm-1.6.x/applications/bin/linux64GccDPOpt/interFoamHeatTransferBlending
0056f000-00571000 rw-p 0006f000 08:11 2159478628                         /home/rm/OpenFOAM/rm-1.6.x/applications/bin/linux64GccDPOpt/interFoamHeatTransferBlending
00571000-00697000 rw-p 00571000 00:00 0                                  [heap]
2ae6a1164000-2ae6a117f000 r-xp 00000000 08:22 14958661                   /lib64/ld-2.4.so
2ae6a117f000-2ae6a1181000 rw-p 2ae6a117f000 00:00 0
2ae6a127f000-2ae6a1281000 rw-p 0001b000 08:22 14958661                   /lib64/ld-2.4.so
2ae6a1281000-2ae6a12ed000 r-xp 00000000 08:22 2968125                    /usr/local/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libinterfaceProperties.so
2ae6a12ed000-2ae6a14ec000 ---p 0006c000 08:22 2968125                    /usr/local/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libinterfaceProperties.so
2ae6a14ec000-2ae6a14ef000 r--p 0006b000 08:22 2968125                    /usr/local/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libinterfaceProperties.so
2ae6a14ef000-2ae6a14f0000 rw-p 0006e000 08:22 2968125                    /usr/local/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libinterfaceProperties.so
2ae6a14f0000-2ae6a14f1000 rw-p 2ae6a14f0000 00:00 0
2ae6a14f1000-2ae6a1555000 r-xp 00000000 08:22 2968066                    /usr/local/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleTransportModels.so
2ae6a1555000-2ae6a1754000 ---p 00064000 08:22 2968066                    /usr/local/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleTransportModels.so
2ae6a1754000-2ae6a1756000 r--p 00063000 08:22 2968066                    /usr/local/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleTransportModels.so
2ae6a1756000-2ae6a1757000 rw-p 00065000 08:22 2968066                    /usr/local/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleTransportModels.so
2ae6a1757000-2ae6a19b6000 r-xp 00000000 08:22 2968088                    /usr/local/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleRASModels.so
2ae6a19b6000-2ae6a1bb6000 ---p 0025f000 08:22 2968088                    /usr/local/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleRASModels.so
2ae6a1bb6000-2ae6a1bbd000 r--p 0025f000 08:22 2968088                    /usr/local/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleRASModels.so
2ae6a1bbd000-2ae6a1bc0000 rw-p 00266000 08:22 2968088                    /usr/local/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleRASModels.so
2ae6a1bc0000-2ae6a1d4e000 r-xp 00000000 08:22 2968068                    /usr/local/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleLESModels.so
2ae6a1d4e000-2ae6a1f4e000 ---p 0018e000 08:22 2968068                    /usr/local/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleLESModels.so
2ae6a1f4e000-2ae6a1f56000 r--p 0018e000 08:22 2968068                    /usr/local/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleLESModels.so
2ae6a1f56000-2ae6a1f59000 rw-p 00196000 08:22 2968068                    /usr/local/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleLESModels.so
2ae6a1f59000-2ae6a2b8f000 r-xpAbgebrochen
When done on one cell, the error is this:
#5  main in "/home/rm/OpenFOAM/rm-1.6.x/applications/bin/linux64GccDPOpt/interFoamHeatTransferBlending"
#7  __gxx_personality_v0 in "/home/rm/OpenFOAM/rm-1.6.x/applications/bin/linux64GccDPOpt/interFoamHeatTransferBlending"
Any pointers would be very much appreciated as to where I can start next to resolve this issue. Thanks a bunch in advance!
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
interface tension question with interFoam solver openTom OpenFOAM Running, Solving & CFD 4 May 29, 2009 13:18
interFoam solver needs pdRefCell? openTom OpenFOAM Running, Solving & CFD 2 May 10, 2009 10:20
Open Channel Flow using InterFoam type solver sxhdhi OpenFOAM Running, Solving & CFD 3 May 5, 2009 21:58
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
