Question on the discretization of momentum equation in icoFoam
Old   October 3, 2011, 02:25
Default Question on the discretization of momentum equation in icoFoam
MPJ
Oliver Pasqual
MPJ is on a distinguished road
Dear foamers,
I have a puzzle in the discretization of momentum equation in icoFoam.
As we know, the momentum equation was integrated over the control volume, and then discretized into linear equation.
When I dig into the code detail term by term of the UEqn, I found that the left hand part of the equation(fvm::ddt(U) + fvm::div(phi,U) - fvm::laplacian(nu,U)) was integrated and then the coefficient of unknow variables were added into the matrix A.
None of the terms is divided by the control volume.....
code detail of fvm::ddt using Euler scheme:
template<class Type>
tmp<fvMatrix<Type> >
EulerDdtScheme<Type>::fvmDdt
    const GeometricField<Type, fvPatchField, volMesh>& vf
    tmp<fvMatrix<Type> > tfvm
        new fvMatrix<Type>
            vf,
            vf.dimensions()*dimVol/dimTime
    fvMatrix<Type>& fvm = tfvm();
    scalar rDeltaT = 1.0/mesh().time().deltaTValue();
    fvm.diag() = rDeltaT*mesh().V();
    if (mesh().moving())
        fvm.source() = rDeltaT*vf.oldTime().internalField()*mesh().V0();
    else
        fvm.source() = rDeltaT*vf.oldTime().internalField()*mesh().V();
    return tfvm;
To the right hand part of the momentum equation, first we integrate the term(fvc::div(p)) over the entire CV. then it was discretized using the Gauss law.
But the result was divided by the volume of the current grid.
code detail of fvc::grad(p) using GraussGrand:
Foam::fv::gaussGrad<Type>::gradf
    const GeometricField<Type, fvsPatchField, surfaceMesh>& ssf,
    const word& name
    typedef typename outerProduct<vector, Type>::type GradType;
    const fvMesh& mesh = ssf.mesh();
    tmp<GeometricField<GradType, fvPatchField, volMesh> > tgGrad
        new GeometricField<GradType, fvPatchField, volMesh>
            IOobject
                name,
                ssf.instance(),
                mesh,
                IOobject::NO_READ,
                IOobject::NO_WRITE
            mesh,
            dimensioned<GradType>
                "0",
                ssf.dimensions()/dimLength,
                pTraits<GradType>::zero
            zeroGradientFvPatchField<GradType>::typeName
    GeometricField<GradType, fvPatchField, volMesh>& gGrad = tgGrad();
    const labelUList& owner = mesh.owner();
    const labelUList& neighbour = mesh.neighbour();
    const vectorField& Sf = mesh.Sf();
    Field<GradType>& igGrad = gGrad;
    const Field<Type>& issf = ssf;
    forAll(owner, facei)
        GradType Sfssf = Sf[facei]*issf[facei];
        igGrad[owner[facei]] += Sfssf;
        igGrad[neighbour[facei]] -= Sfssf;
    forAll(mesh.boundary(), patchi)
        const labelUList& pFaceCells =
            mesh.boundary()[patchi].faceCells();
        const vectorField& pSf = mesh.Sf().boundaryField()[patchi];
        const fvsPatchField<Type>& pssf = ssf.boundaryField()[patchi];
        forAll(mesh.boundary()[patchi], facei)
            igGrad[pFaceCells[facei]] += pSf[facei]*pssf[facei];
    igGrad /= mesh.V();
    gGrad.correctBoundaryConditions();
    return tgGrad;
so my puzzle is that: the right hand part of U equation was divided by the volume, but the left part was not ...
the left hand part must be also divied by the volume in some place, but I can't figure it out...
any hint will be highly appreciated.
thanks
M.P J
MPJ is offline   Reply With Quote
Old   October 3, 2011, 10:49
MPJ
Oliver Pasqual
perhaps the problem has not been discribed clearly.......
as we know, all the term of the momentum equation must be divided by the cell volumes,
when dig into the detail of the code implementation,
only the R.H.S of U equation was divided by the volume in the discretization process of fvc::grad(p).
How about the L.H.S of the equation?
From the discretization process of fvm::, all the term were integrated over the entire volume. I can't find the code on the division operation for them terms ....
can somebody give any suggestion?
thanks.
Old   October 4, 2011, 02:49
Elvis
elvis will become famous soon enough
have you read http://openfoamwiki.net/index.php/IcoFoam ?
hope that gets you further
elvis is offline   Reply With Quote
Old   October 4, 2011, 09:44
MPJ
Oliver Pasqual
Thanks for your kindly reply,elvis
I am new to OF.
I have read the the detail discription of icoFoam several times.
A long time's debug found that the secret lies in the operation overloading of fvMatrix.
and now I am more clear about the discretization of equations using the language of OpenFOAM.
thanks
M.P J
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Space and time discretization of Euler equation Hooman Main CFD Forum 2 June 6, 2010 08:30
Derivation of Momentum Equation in Integral Form Demonwolf Main CFD Forum 2 October 29, 2009 19:53
Derivation of Momentum Equation jbambery Main CFD Forum 1 June 9, 2006 13:27
Nonstaggered Grids and Momentum Interpolations S. Wang Main CFD Forum 3 March 2, 2001 13:44
