Easy way to take surface average at different planes?
Old   January 29, 2011, 15:54
Question Easy way to take surface average at different planes?
Charlie
cheng1988sjtu is on a distinguished road
Hi Foamers:
Now I'm working on channelFoam to reproduce the log-law and turbulence intensity. I just finished my first try using dynSmagorinsky. However, I've got some problems about the post-Processing.
1.
in the log file, I found that
Time = 10
Uncorrected Ubar = 0.1335 pressure gradient = 0.000133009
ExecutionTime = 172139 s ClockTime = 345743 s
Calculating averages
Is the 'pressure gradient' normalized by 'rho' already? I've seem some threads about it and got confused. Basically I need to use it to calculate the wall shear velocity, so it's very important to understand that.
2. Although in the 'controlDict' file, we have fieldAverage, but It seems that it is just a time average in the UMean, Pmean files, so I have 2 questions on that: a.> iis it averaged from t=0? even if it's not steady state? b>. Is there any existing utility that I can use to take a surface average of U and P? BTW, I may need to take surface average at several planes, so maybe sampling is not such a good choice for me. Any suggestions?
Thank you, foamers!
Zhen
cheng1988sjtu is offline   Reply With Quote
Old   January 31, 2011, 14:52
Steven van Haren
stevenvanharen is on a distinguished road
Originally Posted by cheng1988sjtu View Post
Hi Foamers:
1.
Time = 10
Yes, I think all the incompressible solvers assume rho = 1. That is why the density does not appear in the momentum equation and you have to specify kinematic viscosity instead of dynamic viscosity.
Thank you, foamers!
Zhen
a) Yes, do not expect the code to identify the steady state for you
b) If you play around with the 'sample' utility you can do quite a lot. See your source code for an example of the sampleDict file.
stevenvanharen is offline   Reply With Quote
Old   January 31, 2011, 23:35
Default thank you!
Charlie
Hi Steven,
Thank you very much, it's really helpful.
I've looked into the source file for the field average, and yes, the average is taken from t=0 if you didn't specify the starting point of averaging.
Also the postChannel utility turns out to be a good choice for analyzing the channel flow.
Thank you!
Zhen
Old   October 19, 2011, 17:46
Unhappy postChannel
tonkiplis is on a distinguished road
Hi Charlie,
I'm trying to run the channel395 tutorial. I encounter troubles at the post processing step. I added k in the fieldAverage function present in the controlDict.
My questions is: I obtain for k after postChannel utility:
k
kMean
k.xy
I assume k is the SGS turbulent kinetic energy (based on previous posts concerning post processing of LES) kMean is therefore <k> "time averaged value". k.xy would therefore be the <k> value averaged over the homogenous directions?
What is exaclty UPrime2Mean and u.xy, v.xy, w.xy??
I assume UPrime2Mean=<u_i' u_j'> and u.xy to be u_rms--> Sqrt(<u'u'>)?
Am I right?
Any inside would be apreciable..
How can I compare my k to k obtained by DNS?? I don't know how to account for the SGS turbulent kinetic energy.
Question solved.
tonkiplis is offline   Reply With Quote
pressure gradient, surface average
surface planes in gambit falak FLUENT 11 September 12, 2014 15:38
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? jash ANSYS Meshing & Geometry 19 July 23, 2013 18:48
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
Equilibrium of a free surface under surface tensio Ryan Main CFD Forum 1 August 7, 2001 16:14
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 06:47
