October 10, 2011, 23:30 |
Parallelizing a code that involves OpenFOAM
Nicolas
Rep Power: 14 |
I am writing a code to compute periodic solutions in fluid dynamics using a arclength continuation method that involves OpenFOAM functions as subroutines. At each iteration of a main loop, OpenFOAM is used to integrate the Navier-Stokes equations. The obtained solution is post-processed and modified and this new result is then used for the next integration by OpenFOAM and so on. How can I parallelize such a code? I've read some topics and documents about parallel programming with OpenFOAM and apparently, the software uses some functions decomposeParDict and recomposeParDict that are in general run separately, and a library PStream. Can I use decomposeParDict/recomposeParDict inside the code? Do I have to parallelize everything with MPI without PStream because of the structure of my code? Thanks in advance for your answers. Nicolas Périnet |
October 11, 2011, 03:55 |
Anton Kidess
Rep Power: 29 |
Typically, you use decompose at the start of the simulation, and reconstruct at the end of it. I believe parallelization is done using PStream to scatter and gather data on processor boundary patches, and PStream is built on top of MPI functions. You should be able to use PStream if it makes your life easier (I can't tell if it will). If not, you can surely use the underlying MPI functions directly.
November 23, 2011, 18:59 |
Nicolas
Rep Power: 14 |
Thanks a lot Anton for your advises.
I continue on this thread after a long time of wandering. I've tried to make interact Openfoam with MPI. The useful objects are defined in the file UPStream.H. for instance: -number of processes : nProcs, -index of the process [from 0 (masterNo) to nprocs-1]: myProcNo, -index of master process: masterNo, etc... typing for instance Code:
Foam::UPstream::myProcNo() Now, I'm trying to use Openfoam in a loop initialized in a fortran subroutine which is itself part of a main code in C++ involving OpenFOAM functions. It compiles but when I'm running the code I get the error message Code:
Calling MPI_Init or MPI_Init_thread twice is erroneous. Code:
#include SetRootCase If I comment the call to setRootCase inside the loop, I also get error messages. Apparently it is possible to use the function MPI_Initialized to avoid initializing MPI again, but I don't know yet how to use it. I'm afraid there will be a lot of work to do and I'll have to modify a bunch a files to achieve this. I would be grateful to anybody that could help to get rid of this error. |
November 24, 2011, 01:27 |
Nicolas
Rep Power: 14 |
after having searched for a while, I've found that mpi_initialize seems to be indeed a good solution since the code is now working better, I don't know yet on what extent, but it doesn't stop at the beginning of the loop with the previous error message.
I replaced in UPstream.C the line Code:
MPI_Init(&argc, &argv); Code:
int is_initialized; MPI_Initialized(&is_initialized); if(!is_initialized) { MPI_Init(&argc, &argv); } The library containing UPstream.C has to be recompiled. UPstream.C is in Code:
$WM_PROJECT_DIR/src/Pstream/mpi Code:
wmake libso |
Display Modes | |
Access source code of OpenFOAM | nmansouri | OpenFOAM | 1 | October 14, 2010 03:17 |
OpenFOAM 1.5.x package - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 7 | July 30, 2009 04:14 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 06:56 |
OpenFOAM Debian packaging current status problems and TODOs | oseen | OpenFOAM Installation | 9 | August 26, 2007 14:50 |
Parallelizing User Code for Fluent 4.5 | Greg Perkins | FLUENT | 1 | September 25, 2000 20:51 |
