locationInMesh to define two regions(blocks)? |
December 19, 2011, 15:41 |
Aqua
Rep Power: 14 |
Dear all,
I am trying to use moving mesh, so there are two blocks which will move towards each other. in each block there is a small cube inside. So i am trying to use snappyHexMesh to create mesh for the small cubes. So you can see, there are two blocks, means two regions. the problem is related to "locationInMesh": if I give a point in block1, then after snappyHexMesh, there will be 0 mesh in block2; if i give a pint in block2, then then after snappyHexMesh, there will be 0 mesh in block1; please, how i can tell "snappyHexMesh" to work for both blocks? thank you so much!!! |
January 4, 2012, 17:28 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Aqua,
I'm sorry for bringing up this thread out of the past, but I'm just tying-in some loose ends for future readers... For those reading this thread and wondering about the same question, Aqua also asked about this on another thread and I replied here: http://www.cfd-online.com/Forums/ope...tml#post337890 post #20 Best regards, Bruno
Display Modes | |
Installing OF 1.6 on Mac OS X | gschaider | OpenFOAM Installation | 129 | June 19, 2010 10:23 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 12:48 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 09:23 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
UDF FOR UNSTEADY TIME STEP | mayur | FLUENT | 3 | August 9, 2006 11:19 |
