January 12, 2012, 18:33 |
patch definiton inside mesh
ak
Rep Power: 14 |
Hello FOAMers,
I'd like to define a patch inside the mesh region, so that I can specify the temperature on the patch (inside the solver code) to cause ignition. Is it possible to define this internal patch in the blockMesh file? If so, how can this be done? (This patch is not a boundary) Many thanks, Amit |
January 13, 2012, 09:34 |
Rep Power: 16 |
You can use the OF application "createBaffles" to add internalFaces to an existing Patch.
Regards, Jens |
Display Modes | |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 05:24 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
chtMultiRegionFoam Tutorial | m.nichols19 | OpenFOAM | 12 | September 9, 2010 12:56 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
