How to extract Ax=B from solver for debugging
Old   January 29, 2012, 01:04
Default How to extract Ax=B from solver for debugging
sontac is on a distinguished road
I'm current viewing through the source code for icoFOAM. However I'm really interest in the actually matrix A and B in the Ax=B. I'm planning on tweaking the solver a litle and want to see the actual change on the A and B matrix for debugging purpose. I'm a little stuck as writing the A, the x, the B matrix out to a ascii file for analysis..
Any help is appreciated!!!
sontac is offline   Reply With Quote
Old   January 29, 2012, 07:15
Paulo Vatavuk
vatavuk is on a distinguished road
Hi sontac,
You can find some information in this page of the wiki:
http://openfoamwiki.net/index.php/Op...x_coefficients
I hope it helps,
Paulo
vatavuk is offline   Reply With Quote
Old   January 30, 2012, 03:48
Elvis
elvis will become famous soon enough
maybe pythonflu is a valuable tool for you
see this post why it might help you
http://www.cfd-online.com/Forums/ope...tml#post302921
elvis is offline   Reply With Quote
Old   January 30, 2012, 08:32
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hi Sontac, I think the perfect tool for you is gdbOF
http://openfoamwiki.net/index.php/Contrib_gdbOF
it is a tool attachable to gdb that helps you to extract FOAM data from memory in a transparent way, in your case you have to use the gdbOF tool
pfvmatrixfull
which dumps the matrix to a file
Enjoy it!
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
A New Solver for Supersonic Combustion nakul OpenFOAM Announcements from Other Sources 19 February 27, 2024 09:44
[Other] A New Solver for Supersonic Combustion nakul OpenFOAM Community Contributions 20 February 22, 2019 09:08
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
Error during Solver cfd guy CFX 4 May 8, 2001 06:04
