March 16, 2012, 05:33 |
Heat Transfer
ahmed
hi
For my project, I want to solve some heat transfer cases.
CFD user |
March 17, 2012, 08:51 |
A_R
Dear Ahmed
do you realy know OpenFOAM. you look not familiar to this code |
March 20, 2012, 04:43 |
Roman Thiele
Rep Power: 20 |
I think the easiest is you take a look at the user guide http://www.openfoam.org/docs/user/ and start with the first tutorial on lid driven cavity to get familiar with the code. When you install openfoam you will have noticed that you copied tutorials to you home directory. in this tutorial folder you find tutorials to most of the solvers based on use cases.
in the user guide under standard solver you will also find which kind of solver you want to use for different applications http://www.openfoam.org/docs/user/standard-solvers.php don't start out with the most complicated and work your way through some of the tutorials and additionally use the forum's search function for more information, many times problems that occur have been solved at least once in this forum.
~roman |
Heat transfer coefficient - what is waht | Stan | FLUENT | 28 | December 29, 2021 16:29 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 18:53 |
