April 4, 2012, 10:36 |
Memory allocation error
Samuele Z
Rep Power: 18 |
Dear All,
when I try to compile my solver I get this error: Code:
lab@lab-laptop:~/Documenti/cases_OF/OF_case09_steady_vs_unsteady/unsteady_new_solver$ buoyantPimpleFoam_Epta /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.0-0bc225064152 Exec : buoyantPimpleFoam_Epta Date : Apr 04 2012 Time : 16:04:24 Host : "lab-laptop" PID : 8695 Case : /home/lab/Documenti/cases_OF/OF_case09_steady_vs_unsteady/unsteady_new_solver nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Reading thermophysical properties Selecting thermodynamics package hRhoThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>> Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model type RASModel Selecting RAS turbulence model kEpsilon --> Upgrading k to employ run-time selectable wall functions Backup original k to k.old Writing updated k --> Upgrading epsilon to employ run-time selectable wall functions Backup original epsilon to epsilon.old Writing updated epsilon --> Creating mut to employ run-time selectable wall functions Writing new mut --> Creating alphat to employ run-time selectable wall functions Writing new alphat kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.33; sigmak 1; sigmaEps 1.3; Prt 1; } Calculating field g.h Reading field p_rgh Creating field dpdt Creating field kinetic energy K Creating field source list from sourcesProperties Selecting source model type vectorExplicitSetValue Source: air_infinite - selecting cells using cellSet air_infinite - selected 2730 cell(s) with volume 1.2 Courant Number mean: 0.00561315 max: 5.02789 PIMPLE: no residual control data found. Calculations will employ 2 corrector loops Starting time loop Courant Number mean: 0.000837302 max: 0.75 deltaT = 0.0298336 Time = 0.0298336 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 PIMPLE: iteration 1 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.00790783, No Iterations 9 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.00680865, No Iterations 9 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.00501205, No Iterations 4 DILUPBiCG: Solving for Ux, Initial residual = 0.862811, Final residual = 0.00698018, No Iterations 9 DILUPBiCG: Solving for Uy, Initial residual = 0.9982, Final residual = 0.00717148, No Iterations 6 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.00669064, No Iterations 4 DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 0.00623696, No Iterations 9 GAMG: Solving for p_rgh, Initial residual = 0.784028, Final residual = 0.00782346, No Iterations 26 GAMG: Solving for p_rgh, Initial residual = 0.309003, Final residual = 0.00297538, No Iterations 4 GAMG: Solving for p_rgh, Initial residual = 0.013951, Final residual = 0.000138292, No Iterations 15 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 2.73457e-06, global = 6.01253e-07, cumulative = 6.01253e-07 GAMG: Solving for p_rgh, Initial residual = 0.36485, Final residual = 0.00335559, No Iterations 23 GAMG: Solving for p_rgh, Initial residual = 0.372822, Final residual = 0.00354448, No Iterations 4 GAMG: Solving for p_rgh, Initial residual = 0.0297191, Final residual = 0.000291083, No Iterations 14 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 2.18813e-06, global = 4.60073e-07, cumulative = 1.06133e-06 GAMG: Solving for p_rgh, Initial residual = 0.211612, Final residual = 0.00193563, No Iterations 21 GAMG: Solving for p_rgh, Initial residual = 0.101935, Final residual = 0.000883467, No Iterations 6 GAMG: Solving for p_rgh, Initial residual = 0.00600616, Final residual = 5.97428e-05, No Iterations 16 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 2.85086e-07, global = 6.20084e-08, cumulative = 1.12333e-06 Sono qui: file .C Ora sono qui: file .C. Sempre tutto ok! PIMPLE: iteration 2 DILUPBiCG: Solving for Ux, Initial residual = 0.575807, Final residual = 6.74872e-10, No Iterations 32 DILUPBiCG: Solving for Uy, Initial residual = 0.483661, Final residual = 9.24265e-10, No Iterations 31 DILUPBiCG: Solving for Uz, Initial residual = 0.821023, Final residual = 8.99823e-10, No Iterations 27 *** glibc detected *** buoyantPimpleFoam_Epta: corrupted double-linked list: 0x00000000029df480 *** ======= Backtrace: ========= /lib/libc.so.6(+0x77806)[0x7fe9170b2806] /lib/libc.so.6(+0x7c5e4)[0x7fe9170b75e4] /lib/libc.so.6(__libc_malloc+0x6e)[0x7fe9170b77de] /usr/lib/libstdc++.so.6(_Znwm+0x1d)[0x7fe91792324d] /usr/lib/libstdc++.so.6(_Znam+0x9)[0x7fe917923369] buoyantPimpleFoam_Epta(_ZNK4Foam7fvPatch18patchInternalFieldIdEENS_3tmpINS_5FieldIT_EEEERKNS_5UListIS4_EE+0xbc)[0x43536c] buoyantPimpleFoam_Epta(_ZNK4Foam12fvPatchFieldIdE18patchInternalFieldEv+0x15)[0x435435] buoyantPimpleFoam_Epta(_ZNK4Foam12fvPatchFieldIdE6snGradEv+0x41)[0x451dc1] /opt/openfoam210/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam2fv9gaussGradIdE25correctBoundaryConditionsERKNS_14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEERNS3_INS_6VectorIdEES4_S5_EE+0x237)[0x7fe918c72ba7] /opt/openfoam210/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZNK4Foam2fv9gaussGradIdE8calcGradERKNS_14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEERKNS_4wordE+0x96)[0x7fe918c86346] buoyantPimpleFoam_Epta(_ZNK4Foam2fv10gradSchemeIdE4gradERKNS_14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEERKNS_4wordE+0xfe)[0x45580e] /opt/openfoam210/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZNK4Foam2fv15correctedSnGradIdE18fullGradCorrectionERKNS_14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEE+0x1ba)[0x7fe91905861a] /opt/openfoam210/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZNK4Foam2fv15correctedSnGradIdE10correctionERKNS_14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEE+0x9)[0x7fe9190523c9] /opt/openfoam210/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZNK4Foam2fv12snGradSchemeIdE6snGradERKNS_14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEE+0x104)[0x7fe919053d54] buoyantPimpleFoam_Epta(_ZN4Foam3fvc6snGradIdEENS_3tmpINS_14GeometricFieldIT_NS_13fvsPatchFieldENS_11surfaceMeshEEEEERKNS3_IS4_NS_12fvPatchFieldENS_7volMeshEEERKNS_4wordE+0x4d)[0x448d4d] buoyantPimpleFoam_Epta(_ZN4Foam3fvc6snGradIdEENS_3tmpINS_14GeometricFieldIT_NS_13fvsPatchFieldENS_11surfaceMeshEEEEERKNS3_IS4_NS_12fvPatchFieldENS_7volMeshEEE+0x6e)[0x448eae] buoyantPimpleFoam_Epta[0x4231ce] /lib/libc.so.6(__libc_start_main+0xfd)[0x7fe917059c4d] buoyantPimpleFoam_Epta[0x4207e9] ======= Memory map: ======== 00400000-004a6000 r-xp 00000000 08:01 2363070 /home/lab/OpenFOAM/lab-2.1.0/platforms/linux64GccDPOpt/bin/buoyantPimpleFoam_Epta 006a6000-006a8000 r--p 000a6000 08:01 2363070 /home/lab/OpenFOAM/lab-2.1.0/platforms/linux64GccDPOpt/bin/buoyantPimpleFoam_Epta 006a8000-006a9000 rw-p 000a8000 08:01 2363070 /home/lab/OpenFOAM/lab-2.1.0/platforms/linux64GccDPOpt/bin/buoyantPimpleFoam_Epta 01c22000-0c25d000 rw-p 00000000 00:00 0 [heap] 7fe90c000000-7fe90c021000 rw-p 00000000 00:00 0 7fe90c021000-7fe910000000 ---p 00000000 00:00 0 7fe911490000-7fe912c35000 rw-p 00000000 00:00 0 7fe912e41000-7fe9139fe000 rw-p 00000000 00:00 0 7fe9139fe000-7fe913a0a000 r-xp 00000000 08:01 1838542 /lib/libnss_files-2.11.1.so 7fe913a0a000-7fe913c09000 ---p 0000c000 08:01 1838542 /lib/libnss_files-2.11.1.so 7fe913c09000-7fe913c0a000 r--p 0000b000 08:01 1838542 /lib/libnss_files-2.11.1.so 7fe913c0a000-7fe913c0b000 rw-p 0000c000 08:01 1838542 /lib/libnss_files-2.11.1.so 7fe913c0b000-7fe913c15000 r-xp 00000000 08:01 1838528 /lib/libnss_nis-2.11.1.so 7fe913c15000-7fe913e14000 ---p 0000a000 08:01 1838528 /lib/libnss_nis-2.11.1.so 7fe913e14000-7fe913e15000 r--p 00009000 08:01 1838528 /lib/libnss_nis-2.11.1.so 7fe913e15000-7fe913e16000 rw-p 0000a000 08:01 1838528 /lib/libnss_nis-2.11.1.so 7fe913e16000-7fe913e1e000 r-xp 00000000 08:01 1838527 /lib/libnss_compat-2.11.1.so 7fe913e1e000-7fe91401d000 ---p 00008000 08:01 1838527 /lib/libnss_compat-2.11.1.so 7fe91401d000-7fe91401e000 r--p 00007000 08:01 1838527 /lib/libnss_compat-2.11.1.so 7fe91401e000-7fe91401f000 rw-p 00008000 08:01 1838527 /lib/libnss_compat-2.11.1.so 7fe91401f000-7fe914042000 r-xp 00000000 08:01 1973877 /opt/openfoam210/platforms/linux64GccDPOpt/lib/libthermophysicalFunctions.so 7fe914042000-7fe914242000 ---p 00023000 08:01 1973877 /opt/openfoam210/platforms/linux64GccDPOpt/lib/libthermophysicalFunctions.so 7fe914242000-7fe914243000 r--p 00023000 08:01 1973877 /opt/openfoam210/platforms/linux64GccDPOpt/lib/libthermophysicalFunctions.so 7fe914243000-7fe914244000 rw-p 00024000 08:01 1973877 /opt/openfoam210/platforms/linux64GccDPOpt/lib/libthermophysicalFunctions.so 7fe914244000-7fe914334000 r-xp 00000000 08:01 1973780 /opt/openfoam210/platforms/linux64GccDPOpt/lib/libliquidProperties.so 7fe914334000-7fe914534000 ---p 000f0000 08:01 1973780 /opt/openfoam210/platforms/linux64GccDPOpt/lib/libliquidProperties.so 7fe914534000-7fe914537000 r--p 000f0000 08:01 1973780 /opt/openfoam210/platforms/linux64GccDPOpt/lib/libliquidProperties.so 7fe914537000-7fe914538000 rw-p 000f3000 08:01 1973780 /opt/openfoam210/platforms/linux64GccDPOpt/lib/libliquidProperties.so 7fe914538000-7fe914547000 r-xp 00000000 08:01 1973861 /opt/openfoam210/platforms/linux64GccDPOpt/lib/libsolidProperties.so 7fe914547000-7fe914747000 ---p 0000f000 08:01 1973861 /opt/openfoam210/platforms/linux64GccDPOpt/lib/libsolidProperties.so 7fe914747000-7fe914748000 r--p 0000f000 08:01 1973861 /opt/openfoam210/platforms/linux64GccDPOpt/lib/libsolidProperties.so 7fe914748000-7fe914749000 rw-p 00010000 08:01 1973861 /opt/openfoam210/platforms/linux64GccDPOpt/lib/libsolidProperties.soAborted Do you know, by chance, the possible reasons of this message.. Thanks a lot, Sam |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
compile errors of boundary condition "expDirectionMixed" | liying02ts | OpenFOAM Bugs | 2 | February 1, 2010 20:11 |
POSDAT problem | piotka | STAR-CD | 4 | June 12, 2009 08:43 |
attach/detach (valve opening/closing) | phsieh2005 | OpenFOAM Running, Solving & CFD | 2 | March 21, 2009 05:18 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
