setFields.C within solver code
Old   April 4, 2012, 01:29
Default setFields.C within solver code
ak
newOFuser is on a distinguished road
Hi
Does anyone know if it is possible to call setFields.C from within the solver C code? What is the correct procedure since both C codes have main function (and this gives an error).
Still learning C++!
ak
newOFuser is offline   Reply With Quote
Old   April 5, 2012, 04:01
Sachin Kanetkar
sachin is on a distinguished road
Hi AK...
Probably a very stupid answer..but hope it helps ...
Create your own solver ... and change name of setFields.C keeping the references same and change the mail function in it to your name...
Might work ... If it doesnt... dont blame me
Best Luck
Sachin
sachin is offline   Reply With Quote
Old   April 5, 2012, 06:13
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Originally Posted by newOFuser View Post
Hi
Still learning C++!
ak
Hi ak,
what fields do you want to set? You probably only need a few lines of code to set the fields you want.
For example, if you want to set the value of a volScalarField vsf based on the x coordinate of the cell centre:
forAll(mesh.C(). celli) // for all mesh cell centres
  if(mesh.C()[celli].component(vector::X) > 3.1)
    vsf.internalField()[celli] = 1;
  else
    vsf.internalField()[celli] = 0;
Philip
bigphil is offline   Reply With Quote
Old   April 9, 2012, 10:15
ak
Thanks for your replies. I wanted to change the temperature, which has a constant access in the source code. So unless I add a non constant access to T in the source code, I have to use other ways to change T.
I tried some ways based on what I found in the forum, and found that using setFields works. But I want to use it to change T over a few time steps, and so am looking to include it in the solver.
Following is the code I use (and it works) but for this to work, I need to have time directories after each computation. Any ways to avoid this and use the previous time step computations directly, without creating time directories?
Info<<"Igniting"<<endl;
timeSelector::addOptions();
instantList timeDirs = instantList(1, instant(runTime.value(), runTime.timeName())); //writeInterval has to be same as computational 'fixed' deltaT
Info<< "Reading setFieldsDict\n" << endl;
IOdictionary setFieldsDict
IOobject
"setFieldsDict",
runTime.constant(),
mesh,
IOobject::MUST_READ,
IOobject::NO_WRITE
Info<< "Setting field region values" << endl;
PtrList<entry> regions(setFieldsDict.lookup("regions"));
forAll(regions, regionI)
const entry& region = regions[regionI];
autoPtr<topoSetSource> cellSelector =
topoSetSource::New(region.keyword(), mesh, region.dict());
cellSet selectedCellSet
mesh,
"cellSet",
mesh.nCells()/10+1 // Reasonable size estimate.
Info<<"Step a"<<endl;
cellSelector->applyToSet
topoSetSource::NEW,
selectedCellSet
Info<<"Step b"<<endl;
PtrList<setField> fieldValues
region.dict().lookup("fieldValues"),
setField::iNew(mesh, selectedCellSet.toc())
Info<<"Step c"<<endl;
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
Disabling and Enabling Solver Summary Outputs within code adona058 OpenFOAM Running, Solving & CFD 3 November 1, 2007 11:00
free C code for large sparse matrix linear solver ztdep Main CFD Forum 7 May 24, 2007 14:14
AMG solver code Ankan Main CFD Forum 1 May 9, 2007 11:44
Open source CFD code development, possible? Dr. Yazid Bindar Main CFD Forum 27 July 18, 2000 00:18
