[General] data range problem
Old   September 30, 2012, 13:33
Default data range problem
Brian
bptsj is on a distinguished road
I'm very new to ParaView and am using it for output from Elmer FEA. I'm loading a file case001.vtu and do see the mesh structure along with a 'temperature' data label. However the data range is [0 322] which is incorrect. In other post processors the true range is [322.0 349.79].
Any thoughts as to what I'm doing wrong?
Thanks,
Brian
bptsj is offline   Reply With Quote
Old   October 5, 2012, 10:35
Retired Super Moderator
Bruno Santos
Greetings Brian and welcome to the forum!
There might be an export problem in Elmer, where the ".vtu" file wasn't properly created.
You can try and use the menu "File -> Save Data" to export to CSV and then inspect in Calc/Excel where exactly ParaView is seeing the 0 values.
It could also be a problem related to surface vs volume mesh. In other words, in the other post-processors you might be seeing the volume mesh, but on ParaView you're seeing the surface mesh. That would explain why you have 0 values in ParaView.
Best regards,
Bruno
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 01:47
[General] problem with extracting data from paraview a.hajisharifi ParaView 5 April 29, 2016 11:38
Problem in sampling data of custom field function in ANSYS FLUENT v14 apek_great ANSYS 1 February 26, 2014 05:10
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 14:06
Problem in Track Data selen Siemens 2 August 7, 2003 13:06
