[General] Paraview problem while launching
Old   May 11, 2013, 05:02
Default Paraview problem while launching
Tobi's Avatar
Tobias Holzmann
I am using Paraview for 4 years now but that error I never got.
When I am running
~: paraview
I get the following error:
/home/utkarsh/Dashboards/MyTests/NightlyMaster/ParaViewSuperbuild-Release/paraview/src/paraview/VTK/GUISupport/Qt/vtkEventQtSlotConnect.cxx, line 68
vtkEventQtSlotConnect (0xb14ea0): Cannot connect NULL objects.
But there is no folder or user called utkarsh
paraFoam works but paraview not
Can someone give me some advice?
Thanks tobi
Old   May 11, 2013, 15:10
Retired Super Moderator
Bruno Santos
Hi Tobi,
I need to know a few more details:
  • Which exact version of ParaView are you using and from where?
  • Which Linux Distribution you're using?
Because that sort of error message is somewhat normal... it's the path of the original build that gave the binaries you're using.
Even the pre-built OpenFOAM packages have Mattijs' name in the paths for the error messages
Best regards,
Bruno
Old   May 11, 2013, 15:12
Tobi's Avatar
Tobias Holzmann
Hi Bruno,
nice to hear from you.
The problem is solved. Dont know why but during today it was working again.
I am using the PV version of the third-partys and the latest version binaries from the official homepage.
Tobi
Old   May 11, 2013, 15:25
Bruno Santos
Hi Tobi,
Then my guess is that you accidentally activated 2 OpenFOAM versions in the same terminal... which lead to one ParaView to use the Qt libraries of the other ParaView
Still only one OpenFOAM version was used out of the 2, but the ParaView versions were possibly playing around with each other's Qt
Best regards,
Bruno
[General] Paraview problem translation geometry (5.0.1) Flexflix ParaView 2 June 17, 2019 09:46
ParaView Execute problem insta OpenFOAM Installation 2 June 9, 2014 02:37
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview zhernadi OpenFOAM Meshing & Mesh Conversion 8 July 7, 2011 02:28
[OpenFOAM] Installation problem with ParaView 3.8.0 on openSUSE 11.2 aero_ ParaView 14 August 2, 2010 18:13
[OpenFOAM] Problem with Colors in ParaView sven ParaView 1 May 31, 2009 08:13
