June 7, 2013, 01:58 |
Basic Paraview question
jha
how should I store the coordinates of a particle so that paraview can read it and I can do visualize some particles in a 3D cube of 512x512x512. Pradeep |
June 9, 2013, 16:30 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Pradeep,
The simplest is to save the list of points of the centre of the particles into a CSV file and then import it into ParaView. Best regards, Bruno edit: I saw your other thread related to this - http://www.cfd-online.com/Forums/par...iew-movie.html - but unfortunately I don't know the answer to that one.
June 9, 2013, 23:23 |
jha
But your solution sounds for plotting many particles at one time instant. How do I input a time varying solution? Can you please give me a brief example?
June 10, 2013, 07:37 |
Bruno Santos
Rep Power: 128 |
Hi Pradeep,
A few months ago, I explained how ParaView handles files in a temporal way. Start reading here: http://www.cfd-online.com/Forums/par...tml#post405668 post #4 Best regards, Bruno
June 11, 2013, 07:57 |
jha
Thank you very much. It works just as I wanted now. I have another question. I specify the coordinates in each file, for example:
contents of fileXXX.csv z*,y*,z* I have 100 files like these. But These files correspond to times 0, 6, 12, ...600 and not 0,1,2,..100. I am plotting these particles with another data set for which the times are mentioned clearly in the xmf file. So when I plot these two together, while I want both of them to move in sync, PV plots six csv files for every time interval of the other data set. So these two data sets are not in sync. How can I specify the time in the csv files? |
June 15, 2013, 08:53 |
Bruno Santos
Rep Power: 128 |
Hi Pradeep,
Have you tried the following? Code:
file000.csv file006.csv file012.csv ... file600.csv Bruno
paraview 3.98 |
Basic question on motorBike tutorial | newToOpenFoam | OpenFOAM Running, Solving & CFD | 2 | July 14, 2011 09:50 |
[Gmsh] A basic Gmsh question: 1D transfinite | the_phew | OpenFOAM Meshing & Mesh Conversion | 0 | May 10, 2011 10:58 |
basic question about the pressure | AirS | OpenFOAM Post-Processing | 5 | July 29, 2010 12:07 |
Basic Question | Abhi | FLUENT | 1 | August 4, 2007 08:07 |
Basic question: UDF for wall heat flux | Carl | FLUENT | 1 | August 5, 2006 19:01 |
