[OpenFOAM] Paraview problem
Old   November 27, 2013, 01:17
Default Paraview problem
CFDGuy
mehdinekooee is on a distinguished road
Hello All,
I have installed blueCFD, I can run the tutorial simulations and I know it works because I check different time steps and see the values for pressure and velocity. But when I run the Paraview it just shows an empty box where velocity and pressure is zero. Does anyone have any idea about this problem ?
Thanks.
mehdinekooee is offline   Reply With Quote
Old   November 27, 2013, 17:33
Retired Super Moderator
Bruno Santos
Greetings Mehdi and welcome to the forum!
I'm assuming you've installed blueCFD-SingleCore, correct?
This is a somewhat common problem with people that are trying out OpenFOAM and ParaView/paraFoam for the first time. I'll quote myself from a couple of years ago:
Originally Posted by wyldckat View Post
It's simple:
  • You ran blockMesh, then icoFoam.
  • No errors in sight and you have the 0.1 to 0.5 time folders.
  • You ran paraFoam. ParaView opens with the case folder. You pressed the big green "Apply" button.
  • The mesh/box appears.
  • Now look at the top right half of ParaView's top toolbar and see the "Time" edit box with a spin box to the right (spin box has two triangles, one pointing up and the other down). Click on the top triangle to change the current time snapshot.
  • Then start reading here: Post-processing
To learn more about ParaView and how to use it with OpenFOAM:
Best regards,
Bruno
Old   December 1, 2013, 03:43
CFDGuy
Thanks Bruno, it helps. It works as you said.
Best regards
ParaView Execute problem insta OpenFOAM Installation 2 June 9, 2014 02:37
[General] Problem in using paraview meballav ParaView 11 October 12, 2012 16:03
[OpenFOAM] Installation problem with ParaView 3.8.0 on openSUSE 11.2 aero_ ParaView 14 August 2, 2010 18:13
Yet another Paraview problem gascortado OpenFOAM 5 February 21, 2010 06:39
[OpenFOAM] Problem with Colors in ParaView sven ParaView 1 May 31, 2009 08:13
