[General] periodic visualization in paraview
Like Tree4Likes
  • 2 Post By Flowkersma
  • 1 Post By Flowkersma
Old   September 13, 2015, 08:16
Default periodic visualization in paraview
mohamed mohsen
sehs15 is on a distinguished road
hello,
I'm solving a 10 degrees sector with periodic boundary conditions. I need to view the solution in the entire 360 degrees. Any help about periodic viewing in paraview inducing linear and rotational periodics.
Thanks in advance
sehs15 is offline   Reply With Quote
Old   September 15, 2015, 01:48
Mikko
Flowkersma is on a distinguished road
Hi mohamed,
Unfortunately, there is no native filter which can do this for you. However, you can play with transform filter. Here is a example script how to build the full 360 view from 10 degrees sectors (axis in z-direction) with Python Shell:
source = GetActiveSource()
t = transforms = []
for i in range(0,360,10):
   t=Transform(source)
   t.Transform.Rotate = [0,0,i]
   transforms.append(t)
group = GroupDatasets()
group.Input = transforms
Now the GroupDatasets filter contains the full 360 degrees. Note that this is not memory efficient and the streamlines will not pass the boundaries.
-Mikko
arvindpj and BSengupta like this.
Flowkersma is offline   Reply With Quote
Old   September 15, 2015, 09:06
mohamed mohsen
Thank you Mikko .. how can i load the source?
Old   September 15, 2015, 09:51
Mikko
After the first line of my script the source points to your active source in Paraview which should be the 10 degrees sector that you have opened before.
For completeness, here are all the steps:
1. Open the file with 10 degrees sector
2. Open the Python Shell inside Paraview (Tools->Python Shell)
3. Copy-Paste the script in my previous message to the shell
Now the last filter in your Pipeline Browser (GroupDatasets) should have the full 360 degrees.
BSengupta likes this.
Old   September 19, 2015, 06:06
Mikko
The latest ParaView 4.4 supports this, look at http://www.kitware.com/blog/home/post/906.
wyldckat likes this.
Old   September 21, 2015, 05:08
mohamed mohsen
thank you .. it opened a window for browsing for a python script?!
[OpenFOAM] Visualization of a 3D Flow field (paraview) Chris123 ParaView 2 November 27, 2018 08:51
[Other] Mesh quality visualization in paraview Lieven OpenFOAM Meshing & Mesh Conversion 3 June 20, 2018 19:03
[ICEM] Multizone periodic fails herudae ANSYS Meshing & Geometry 2 April 1, 2013 06:46
Visualization of Secondary Flow with ParaView idrama OpenFOAM 2 May 12, 2012 13:37
OpenFoam 2.0 hopper case visualization with Paraview amscosta OpenFOAM 11 September 15, 2011 02:44
