[General] reproduce preview effects that appears when moving the view
Old   July 19, 2016, 08:27
Default reproduce preview effects that appears when moving the view
philus is on a distinguished road
when you rotate/translate the view of a geometry in paraview a sort of preview is shown till the mouse button is released. This preview triangulate the geometry in a coarse way and contours are projected on them.
Now, I would like to reproduce this effect but being able to control the triangles size. Is there a filter or another way to do what this preview does?
Thanks in advance,
philus
philus is offline   Reply With Quote
Old   July 28, 2016, 03:29
Default decimate filter
Ok, I somehow discovered that the filter "decimate" almost do what I need.
But before I can apply it I have first to apply Extract Surface, then Triangulate and at the end Decimate. But still I am not able to obtain the same thing that I have when I rotate the view.
Can someone give me any suggestion on how to use this filter in order to exactly obtain what I see when I move the geometry?
Thanks in advance,
philus
preview, projection, toggle, triangulation
UDF Moving wall preview strange Iggy_LR Fluent UDF and Scheme Programming 3 February 5, 2016 16:41
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? karkar OpenFOAM Meshing & Mesh Conversion 0 July 4, 2012 06:54
Effects of a moving train to people in a tunnel J. Kim FLUENT 5 February 14, 2012 08:26
[ICEM] Moving Block Nodes In View Plane tav98f ANSYS Meshing & Geometry 5 August 13, 2011 12:58
