August 26, 2016, 08:21 |
Smaller slice plane in paraview
Sathish
The Slice option in Paraview with selection "plane", has a "origin" and "normal" to define the plane.
I am trying to export the slice data in csv format. However, the simulation domain is very large and therefore the slice also is quite large (which needs to be processed in matlab further). I need only the specific region of the slice. Is it possible to reduce the slice by creating a plane based on points by user or any other alternatives? |
August 27, 2016, 13:01 |
Mikko
Rep Power: 12 |
Firstly, use the clip filter to cut the domain smaller and then slice filter. Best, Mikko |
April 22, 2019, 21:49 |
Lisandro Maders
It is better to do the slice and then the clip. The other way around blows the memory!
paraview, plane, slice |
[OpenFOAM] How to calculate mass flow rate through arbitrary rectangle plane in paraview | manoj_nav | ParaView | 7 | April 1, 2016 07:14 |
[OpenFOAM] How to calculate mass flow rate through arbitrary rectangle plane in paraview | manoj_nav | ParaView | 0 | March 10, 2016 02:53 |
[OpenFOAM] Why the color of this slice in paraview is so dark? | sharonyue | ParaView | 3 | May 29, 2015 17:54 |
Installing OpenFOAM and ParaView in VirtualBox(Ubuntu on Win8) | chrisb2244 | OpenFOAM Installation | 2 | August 21, 2013 13:24 |
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview | zhernadi | OpenFOAM Meshing & Mesh Conversion | 8 | July 7, 2011 02:28 |
