September 10, 2017, 11:36 |
Streamlines
Rep Power: 10 |
hello to all,
I would like to visualize the streamlines in a channel. I used the streamtracer command and the visualization is ok. To be more clear, i would like to se also the contour of the channel, as it has been "transparet". Any suggest? Thanks for the help |
September 11, 2017, 04:24 |
#2 | |
Rep Power: 11 |
Maybe what could do the trick for you, is to visualise the PID of interest, change its "coloring" to "solid" under the "properties" tab, adjust the color to white with the "edit" button, and last adjust the opacity to ~0.4 under the "styling" section. Hope that this works for you and good luck with you work. Cheers |
September 11, 2017, 15:19 |
Rep Power: 10 |
Thank you Swempa. It's exactly what i needed.
Best Regards Last edited by FlyBob91; September 12, 2017 at 06:54. |
Using streamlines for flow visualization and diverging residuals | kmiller | STAR-CCM+ | 1 | July 16, 2018 15:50 |
Concentrated Streamlines versus Higher Velocity | eucalyptus | Main CFD Forum | 1 | October 27, 2017 11:54 |
Interpreting streamlines of a rotating fan. | danbence | Visualization & Post-Processing | 1 | April 8, 2014 10:13 |
[General] Problems with streamlines for 2D porous media flow simulations | twophaseflow | ParaView | 4 | February 11, 2014 14:32 |
STAR-CD, moving grid and streamlines | Mohamed GUEROUACHE | Main CFD Forum | 1 | September 13, 1999 13:33 |
