June 12, 2006, 11:48 |
Zero values using sampleSurface
Steffen Jahnke
When I execute sampleSurface (constantPlane, interpolatedPlane) on my parallel case and everything runs fine. After I try to look at the results in paraview 2.4.2 I already get an error message in my console:
Error or warning: There was a VTK Warning in file: ../../../../../paraview-2.4.2/VTK/IO/vtkDataReader.cxx (844) Error reading ascii data! The field to plot is zero. The "Data Range" in paraview also say that everything is zero. But when I apply foamToVTK to the same case I can do a cut with a plane at the same position and everything looks fine. Also paraFoam gives the correct picture. I use OpenFOAM-1.3 on FC5_X86_64 and here is my sampleSurfaceDict: =============================================== surfaceFormat vtk; interpolationScheme cellPointFace; surfaces ( constantPlane { name constantPlane; basePoint (0 0 0); normalVector (0 0 1); // Optional: whether to leave as faces or triangulate (=default) triangulate false; } interpolatedPlane { name interpolatedPlane; basePoint (0 0 0); normalVector (0 0 1); triangulate false; } ); ( p U F cI cD nuSgs ); ================================================ I experienced a similar problem using the probes utility, i.e. zero values eventhough they are not zero. They probably use the same interpolation method. I also checked running in serial and different interpolation methods. Any suggestions are welcome. |
June 13, 2006, 05:53 |
Change your plane so it doesn'
Mattijs Janssens
Rep Power: 26 |
Change your plane so it doesn't coincide with any faces/edges/points. Just perturb by small amount.
If problem persists please create small testcase and send to me. |
June 15, 2006, 04:23 |
Thanks!
Using a slightly diff
Steffen Jahnke
Thanks!
Using a slightly different basepoint for each of 2 coordinates solved the problem, but nevertheless it seems to be very sensitive especially if you have a structured mesh. I had to play around several times to get sampleSurface the right output. |
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 06:55 |
using chemkin | JMDag2004 | OpenFOAM Pre-Processing | 2 | March 8, 2016 22:38 |
Setting patch field values equal to internal field values | leroyv | OpenFOAM Programming & Development | 1 | October 21, 2014 15:49 |
Loading Cell Values in Tecplot | P1361 | OpenFOAM Post-Processing | 3 | September 16, 2014 04:02 |
Plotting raw data values | Wilesco | Siemens | 0 | January 5, 2006 05:34 |
