May 6, 2013, 11:02 |
High velocity error
romulus
I am trying to study spray charactersitics from a nozzle using phoenics ( similar to gas turbine combustion chamber set-up). Using KE Turbulence model, I am getting velocity in the region of 54000m/s. I know it is incorrect as I am expecting to see something in the region of 10-25 m/s (velocity at exit of nozzle).
Initially i was not getting convergence, but this was resolved by tweaking SARAH. start from ambient is off, and I have given pressure=500 psi and tem=120 deg c as initialisation. still the velocity is high. I am kind-of run out of ideas. any ideas or suggestions are much appreciated. Thanks. Nozzle exit dia=0.00044m Nozzle Inlet dia=0.00762m mass flow rate at fuel inlet=2.9kg/s density of fuel=750kg/m3 temp of fuel=120 deg c Air inlet mass flow rate=10kg/s temp of air=400 deg C density of air=0.5 kg/m3 [/IMG] |
May 30, 2013, 08:10 |
Savio
Romulo,
the mass flow rate is seems to be a bit to much for the diameters you gave. A GT will have that king of flow rate but not for a single nozzle. i suggest you divide the mass flow rate with the number of nozzles in the combustor becayse the 2.9kg/s is what the combustor feels from multiple nozzle, not a single nozzle. I also suggest that you run each part at a time i.e only one inlet and air, and than proceed from there. All the best. |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
