February 6, 2001, 15:23 |
Problems with GENTRA
Hi to everyone, and let's go to the topic.
I'm adding tracking particle (GENTRA) to a case I already have. But it shows me the following error, after the first iteration, at the result file: --- INTEGRATION OF EQUATIONS BEGINS --- ************************************************** ***** ??? imat= 30 prps value does not correspond to those placed by SATELLITE in eardat. INIAD=T ? If you need this material, insert in Q1 SPEDAT(SET,MATERIAL, 30,L,T) I have checked my q1 file, and the only number 30 possibly suspicious, is when I define the type of the particle (isothermal). What can I do?? Thanks for any comment... Javier |
ABOUT GENTRA | WING | Phoenics | 1 | August 30, 2006 03:49 |
CAN GENTRA BE USED FOR COMBUSTION | WING | Phoenics | 0 | August 17, 2006 05:48 |
can Gentra do that? | zhao | Phoenics | 2 | January 7, 2004 16:48 |
How can I run a private GENTRA | ben | Phoenics | 3 | January 6, 2004 06:48 |
GENTRA Problem | H.P.LIU | Phoenics | 3 | March 22, 2001 08:18 |
