which program in phoenics can change CAD file |
May 17, 2001, 02:06 |
which program in phoenics can change CAD file into phoenics geometry file? thanks
May 22, 2001, 09:54 |
Re: which program in phoenics can change CAD file
you have to use either 3d face and export it to DXF format, or the better is to make a solid in CAD and then expot it as STL ( non binary) format, then you can import it with no problem into PHOENICS.
I hope this help, Ing. R. Azzawi |
May 22, 2001, 22:50 |
yes, I know that using VR can import STL format file . My question is in phoenics which program do this, do the work import stl file if i doesn't use VR? thank you for your answer.
May 25, 2001, 15:36 |
if you want to do structured grids then there is a package called, i believe, GeoGrid-CSI which i have heard does a wonderful job interfacing with PHOENICS. this package will read in IGES files and then you can work with the CAD data to generate a multiblock structured mesh for import into PHOENICS.
May 29, 2001, 07:48 |
in phoenics/d_intfac/d_cadpho/stlcham.htm, it said that there exist a file call stlcham that can change CAD geometry into phoenics style data file. But where the stlcham is? In phoenics, I can't find it. I didnt want use Vr to import a CAD stl file, I hope I can use stlcham to change CAD stl file into Phoneics data file. Where I can find the program STLCHAM?
How to set mass source term in Phoenics VR program | Dan | Phoenics | 1 | October 23, 2008 20:08 |
how to write a code or program for phoenics??????? | Manjinder | Phoenics | 0 | December 7, 2006 02:06 |
Changing gambit file without change of case file?? | Asghari | FLUENT | 2 | August 28, 2006 14:48 |
where is output data file[PHOENICS] | DSF | Main CFD Forum | 1 | June 8, 2000 10:15 |
where is output data file[PHOENICS] | DSF | Siemens | 0 | May 30, 2000 12:49 |
