Help on EXPERT
Old   July 17, 2001, 17:13
Default Help on EXPERT
Tim
I am new to CFD and PHOENICS and I am trying to simulate natural convection around a series of cylinders. I have been having trouble with convergence so I have tried using EXPERT. I have gotten expert to work with EXPERT=T, NOWIPE=T, and by LOAD(030) into the Q1 file (note that in POLIS it says LOAD(30), which does not work...). However, for some of my simulations that I did get convergence for, using EXPERT resulted in an increase in time and number of iterations before convergence occurred. Is this something that occurrs from time to time? Secondly, I have no information on expsol, expdtf, inres, etc... Where can I find information on this? I perused through the polis but found nothing on these. If I turn expsol to true, what does it do? What does it adjust?
Thank you for any insight on these questions, Tim
Old   July 19, 2001, 05:30
Default Re: Help on EXPERT
Mike Malin
EXPERT has fell into disuse at CHAM as a dynamic relaxation device, largely because it has been superceded by SARAH (Self-Adjusting Relaxation AlgoritHm).
SARAH is documented on-line at the following web address:
http://www.cham.co.uk/phoenics/d_pol...nc_s.htm#sarah
SARAH can be set in the VR Editor or in the Q1 input file by means of the PIL Command SARAH=0.001, for example. Typical values of SARAH range from 0.00001 to 0.1, depending on the application. Like EXPERT it does not always lead to improvement.
Old   August 9, 2001, 16:31
Tim
Thanks Mike, really appreciate the input. Is there any way of determining what a suitable value for SARAH would be or is it simply trial and error? Also, will the initial values used for the false time step relaxation factors affect convergence is using SARAH?
Thanks, Tim
Old   August 13, 2001, 10:02
Mike Malin
The optimim value of SARAH depends on the application, but typically I start with 1.e-3 and if PHOENICS diverges or oscillates, I then use the graphical interrupt facility to lower SARAH to 1.e-4 or even 1.e-5 if need be. If PHOENICS doesn't recover, I can then start again with the lower SARAH value.
I don't believe that the initial DTFALS values should have an effect, but I have not experimented with them, so I cannot be sure without trying.
Old   August 15, 2001, 10:50
Tim
Thanks again Mike!
I have tried using SARAH starting with 1e-3 and I found that it was too large and changed it in flight. Found out that a SARAH value of 1e-5 is what is needed.
Thanks again, Tim
Old   August 21, 2001, 14:15
PattiMichelle
Isn't that funny? I thought that EXPERT was newer than SARAH. I got the impression from the documentation that SARAH was much older. I guess they need a little more updating. Patti
expert parameter sometimes1900 CFX 3 October 27, 2008 11:41
To who are expert Tony FLUENT 1 February 24, 2007 14:26
Combustion expert? HP FLUENT 2 August 16, 2004 03:55
Expert Opinion Rooh-ul-Amin Khuram Siemens 14 July 15, 2000 19:43
FSI/FIV Expert Needed Dmitry Paramonov Main CFD Forum 2 July 31, 1999 12:48
