How to uncompress PHI file
Old   April 22, 2002, 09:34
Default How to uncompress PHI file
Hu
Could anyone tell me how to uncompress the PHI file that has been compressed by runcmp.bat. There is no help document regarding how to uncompress PHI file (which has been renamed as CPHI) in CHAM website. I tried to use runcmp.bat again but it requires a parameter to perform uncompressingt task, otherwise it would only do compressing. Please help.
Old   April 24, 2002, 10:32
Default Re: How to uncompress PHI file
Jeremy Wu
There is an input file called q1cmp where you can specify uncompress or compress. Which PHOENICS version are you using ?
Old   April 24, 2002, 13:02
Hu
Thank you, Jeremy. I am using PHOENICS 3.2 (non-recompilable) and 3.4 (recompilable). The problem is what should I do to the q1cmp? Is it just simply to add a line "uncompress" or "compress"? Is there any parameters I have to add? It seems 'q1cmp' is generated automatically be 'runcmp.bat' because it cannot be found if not using it.
Old   April 25, 2002, 04:52
Jeremy Wu
I will send you a q1cmp file where you can see that there is '*' sign in front of compress (or uncompress) The '*' sign is used to de-activate the command. If you want to uncompress CPHI, then put an '*' sign in front of compress, and remove the '*' sign from the uncompress line.
Old   April 25, 2002, 20:21
Hu
Many thanks for your help! May I ask one more question? What is the unit of the csize (kb? Mb?) I have seen there is a statement 'csize=1000', does it mean the maximum compressed phi file is 1000kb? What are the special cases of csize=1.2 and csize=1.44?
Cheers.
Old   April 26, 2002, 05:35
Jeremy Wu
As descrived in the q1cmp file, the unit of csize is Kb. However, if you specify 1.44 or 1.2, then the program will take it 1440kb or 1200kb as there are statements in the code something like:
if(csize.eq.1.44) then
maxk=1440
elseif(csize.eq.1.2)
maxk=1200
endif
Old   October 10, 2002, 06:18
Ramesh Avvari
Hello... dont complicate things to compress the phi file... it can be simply done by changing the option to yes \ no in compress = ? in cham.ini file... open file, open cham.ini file and just type no for compress = ?/ thats all... u will get phi in numerical ascii format in uncompressed file. but the file size will be big.
Ramesh Avvari
PLOT3D ASCII solution file to MATLAB data file Sandeep Rana Main CFD Forum 4 June 11, 2010 09:48
[OpenFOAM] ParaView exiting while trying to save image file or movie file 21kalee ParaView 3 January 23, 2008 16:01
file/write-profile ... journal file MM FLUENT 5 November 30, 2006 03:07
Changing gambit file without change of case file?? Asghari FLUENT 2 August 28, 2006 13:48
converting a solidworks file into a fluent file rhaul FLUENT 2 June 23, 2006 16:04
