Help on porosity
Old   June 18, 2002, 00:35
Default Help on porosity
Leon Mills
I am trying to model a perforated plasterboard ceiling. I know that the perforations make up 50% of the area of the plasterboard.
Can I use a 'plate' in phoenics and set the perosity=0.5 . The exact flow through the perforations is not important but the flow through the perforated panel is.
I am on the right track ?
Any help would be greatly appreciated.
Leon
Old   June 18, 2002, 08:59
Default Re: Help on porosity
David Connolly
You can use a standard blockage and make the material the domain material. You will then be able to change quite a few aspects of the blockage, including porosity.
porosity in UDF Jin Yan FLUENT 4 December 1, 2009 09:27
UDF for porosity cfd-novice FLUENT 2 August 20, 2009 03:19
porosity ravi FLUENT 2 December 13, 2007 20:50
porosity ravi FLUENT 0 December 13, 2007 01:31
help on porosity ravikanth FLUENT 0 January 21, 2005 12:14
